Need a new rear tire. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 39 (permalink) Old 03-08-2013, 11:32 AM Thread Starter
Hi,
My rear tire is getting thin and intend to buy a shinko tour master rear. The local shop charges $40 to change if I bring them the tire/wheel alone. I want to go this route; however, I only have a car jack to use. Is this doable? If so, how should I proceed w/o droping it? Thanks!
thewiesercracker is offline
post #2 of 39 (permalink) Old 03-08-2013, 11:42 AM
The wife and I do this all the time. Use the floor jack with a piece of 1X4 or something long enough to reach from left to right. Make sure you clear any protrusions which would prevent the bike from sitting flush on the board. Have her sit on the bike and keep the front wheel straight as you slowly jack it up. Once up, we put a cinderblock with a small cut of plywood on top as a stand. We lower the jack just to the point where the bulk of the weight is supported by the block. Cycle Gear in Baton Rouge only charges $20, you may call a Cycle Gear if there's one near you.
mark edward marchiafava is offline
post #3 of 39 (permalink) Old 03-08-2013, 11:50 AM Thread Starter
Thanks for the tip! That'll do nicely. Sadly, I don't have a Cycle Gear in Kansas.
post #4 of 39 (permalink) Old 03-08-2013, 12:04 PM
Vandy's Avatar
Pirelli tires are 40% off at some places. The money saved might be close to what you would pay to have someone do it for you...
But I was treated mercifully because I didn’t know what I was doing—didn’t know Who I was doing it against! Grace mixed with faith and love poured over me and into me. And all because of Jesus. Here’s a word you can take to heart and depend on: Jesus Christ came into the world to save sinners. I’m proof—Public Sinner Number One—of someone who could never have made it apart from sheer mercy.
1Tim 1, MESS Bible
2006 Vulcan900 Classic
Vandy is offline
post #5 of 39 (permalink) Old 03-08-2013, 12:08 PM
SWVA_08V2k's Avatar
That is what I do also. if you have to do it on your own then put you a block under the high side of the frame so when you start to lift it will start to lay over on the block. Afer you start get it even or a little past even but still stable, block that side up then you will have to walk it up the blocks with the jack. it is a little time consuming but it will get you there. I usually get the wife or neighbor or even a set of tie down straps hooked to the roof of my car port (its made form .250 wall steel pipe. not your average car port) to help steady it while I lift it. Then let the weight of the weight rest of the blocks.
Do you have a classic or custom.
SWVA_08V2k is offline
post #6 of 39 (permalink) Old 03-08-2013, 12:09 PM Thread Starter
I've been looking around and the Shinko's are still cheaper.
post #7 of 39 (permalink) Old 03-08-2013, 12:09 PM Thread Starter
It's a custom.
post #8 of 39 (permalink) Old 03-08-2013, 12:13 PM
SWVA_08V2k's Avatar
ok. that will make it easier. You won't have to jack the bike to the moon or take the rear fender off to get the tire and wheel out from under it.
post #9 of 39 (permalink) Old 03-08-2013, 12:16 PM
try to note the markings on the axle adjusters. We try to put them right back where they were.
post #10 of 39 (permalink) Old 03-08-2013, 12:19 PM
SWVA_08V2k's Avatar
good tip. Not only for tire alignment but belt tension too.
In need of rear tire advice for 2010 Voyager 1700 nascarguy67 Vulcan 1700 12 06-28-2016 11:08 PM
Rear Tire Guard Necessary ?? DS Tire Install 2Krogue Vulcan 2000 12 04-21-2015 03:49 PM
Need write up for '04 Meany rear tire removal kissmydrums Wheels and Tires 0 02-13-2015 03:00 PM
Front or Rear Pulley with 200 rear tire? Luna Vulcan 900 4 05-17-2013 10:35 AM
Need Rear Tire (I think) crooksie Wheels and Tires 13 09-05-2009 08:01 PM
