Starting electrical issues HELP - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 23 (permalink) Old 02-27-2013, 02:50 PM Thread Starter
wman5757's Avatar
Year/Make/Model: 2011 Kawasaki/Vaquero
Color: RED
My wifes bike is a 10 vulcan 900 classic. Son road bike to rally and back .It died in driveway.The problem is it wont crank& no head light.I looked at fuses on left side of bike&replaced battery.No results.
Is there another fuse I am missing?
wman5757 is offline
post #2 of 23 (permalink) Old 02-27-2013, 03:13 PM
cobra 1's Avatar
Their is another fuse on the starter relay I think it's 30a which is on the right side under the other panel but I'm not sure if that will stop the lights working as well mine has a spare their too so it's worth having a look
2009 custom special edition
kuryakyn iso grips (black)
v&h twin staggered slash cuts (black)
la choppers intake (black)
cobra fi2000r
smoked lenses and tail light
highway hawk sissy bar (black)
highway hawk engine guard (black)
cobra 1 is offline
post #3 of 23 (permalink) Old 02-27-2013, 03:15 PM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
First thing that comes to mind are some of the switches.
Kill switch. Snap it back and forth a couple time. On older bikes I've had trouble with that. Flipping it back and forth cleans the contacts a bit and sometimes helps.
Kickstand switch. If the stand or the switch is loose it may not be making contact when the stand is up. Did you try starting it neutral?
Then there's the neutral safety switch, but I believe that's inside the tranny. I don't have the shop manual handy.
The connections to the switches could be loose or dirty, you'll want check those.
SteveJB is offline
post #4 of 23 (permalink) Old 02-27-2013, 03:18 PM
don't think those switches would result in no headlight. Had similar issue on a Honda, turned out to be the ignition switch.
mark edward marchiafava is offline
post #5 of 23 (permalink) Old 02-27-2013, 03:24 PM
DoubleTap's Avatar
1st you let your son ride it.
LOL
Sounds like the ignition switch.
Use a volt meter and start checking. start with the battery and work your way to the switch.
_______________________________________
2008 Vulcan 900 Classic
DoubleTap is offline
post #6 of 23 (permalink) Old 02-27-2013, 03:27 PM
SWVA_08V2k's Avatar
What switch kicks the headlight on. I thought the light did not come on until you hit the starter??? That is how it was on my Mean Streak, 1500 Classic, and V2K. I would assume it is the same on the 9's. First thing I would check is all the fuses and safety switches. Assuming your battery is good since you said you put on in it.
SWVA_08V2k is offline
post #7 of 23 (permalink) Old 02-27-2013, 04:14 PM
Originally Posted by SWVA_08V2k View Post
What switch kicks the headlight on. I thought the light did not come on until you hit the starter??? .
Actually, the starter switch disables headlight to reduce electrical load during cranking.
sfair is offline
post #8 of 23 (permalink) Old 02-27-2013, 04:16 PM
Follow positive battery cable back to its destination and there you will find the main fuse on top of the starter solenoid.
This fuse will kill the bike dead if it is blown.
If it is blown, you replace it and it blows again, STOP there.
sfair is offline
post #9 of 23 (permalink) Old 02-27-2013, 08:41 PM Thread Starter
wman5757's Avatar
Color: RED
thank you for some suggestions
thanks to all on some other possibilites. I will let you know what I find out
wman5757 is offline
post #10 of 23 (permalink) Old 02-27-2013, 08:44 PM
Color: Orange SE
On the Vulcan 900, the headlight does not come on until the starter button is 'successfully' pressed. That is, if anything impedes the starter button (like the kickstand switch) the headlight will not come on. When you turn the key, the running lights come on, but the headlight does not. If you just gently tap the starter button (again, with all switches in a position that would allow the bike to start!) the bike won't crank long enough to start, but now the headlight will be on. Basically; the starter switch turns on the headlight.
Romans5.8 is offline
Electrical/Starting Issue red_leg Vulcan 500 17 11-19-2015 06:33 AM
Electrical problems starting AdamX Vulcan 2000 10 09-11-2014 10:25 PM
Electrical/starting problem Meanie Vulcan 1600 10 05-08-2013 08:22 PM
Electrical issues!!! HELP Masterm54 General Vulcan Talk 1 03-20-2012 12:00 PM
Electrical issues mwolcott Vulcan 1500 1 07-06-2009 10:02 PM
