Cold start issues after v&h pipes,k&n ac,and fi2000r - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 02-26-2013, 05:35 PM Thread Starter
Hi
I am new here. I am here to get some help with my brother in-laws 2011 vn900
Just put v&h pipes on with a k&n air cleaner and a fi2000r(which still has the stock settings which are 4 2 0). And we are having cold start issues. It takes several tries to start the bike when cold. But it seems to start with no issues cold with the throttle all the way open which I assume is a flood clear?
Any help will be greatly appreciated
Thanks in advance
03lowrider is offline
post #2 of 10 (permalink) Old 02-27-2013, 03:11 PM Thread Starter
Anyone ? is it a fi2000r pot setting?
post #3 of 10 (permalink) Old 02-28-2013, 11:36 AM
BigTim900's Avatar
Re: Cold start issues after v&h pipes,k&n ac,and fi2000r
With fuel injection you should not have a flooding problem .Try to adjust the idle set knob located infant of the air filter housing.If it is turned to low the motor wont run cold.May just need to turn up a little.hope this helps.
07 900Lt.
BUB JUG HUGGER PIPES
CORA FI2000R
ARLENE NESS BIG SUCKER!
BigTim900 is offline
post #4 of 10 (permalink) Old 02-28-2013, 11:45 AM
Remove the FI2000 and see if the problem is still there.
Post back.
sfair is offline
post #5 of 10 (permalink) Old 02-28-2013, 02:54 PM Thread Starter
i will check the idle set knob
I think if i set the pot settings all to 0 its like the FI2000 is not there correct?
post #6 of 10 (permalink) Old 02-28-2013, 03:24 PM
BigTim900's Avatar
On the FI2000R there is a safety set already programmed into ut.if there is any internal problems it automatically resets itself to 000.
This is what the booklet that came with mine said.so if you set it to that then yes.
post #7 of 10 (permalink) Old 02-28-2013, 04:17 PM
Removing it out of the system is the only way to tell if it is causing the problem.
sfair is offline
post #8 of 10 (permalink) Old 02-28-2013, 05:33 PM Thread Starter
Ok going to try 0 0 0 first.
post #9 of 10 (permalink) Old 02-28-2013, 05:35 PM Thread Starter
Don't think it's the fi2000r because before we put the pipes and ac on
We tested the bike stock with just the fi2000r and it started and ran with no problems.
I am thinking maybe the idle screw
post #10 of 10 (permalink) Old 02-28-2013, 06:38 PM
What if you have an injector driver that did work and now it is failing under low temperatures? Settings will have no influence over this.
If you take the bike into the dealer for this problem, the first thing they will point to/remove is the Cobra in order to rule it out.
Your bike has an ECU controlled cold fast idle over which the knob will have little effect, if any.
sfair is offline
Cold Start Single Cylinder start interceptor_1972 Vulcan 1700 13 05-22-2016 10:31 PM
VN900 Aftermarket parts-Seat, AC, OD Pulley, Lowering Kit VulcanCustomGuy Bike Parts, exhausts, etc. For Sale 22 11-15-2013 05:27 PM
cold start issues wrx4me General Vulcan Talk 17 06-06-2013 09:38 AM
Cobra FI2000r vs. FI2000r Auto Tune dwn0414 Vulcan 900 9 06-25-2012 08:37 PM
cobra FI2000R & V&H pipes islandstylistman Vulcan 900 7 04-21-2009 07:08 AM
