Hyperlites installed - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 07-24-2009, 07:58 PM Thread Starter
sickboy's Avatar
Hi, just thought I would share for those that like people to be able to see them at night.
I installed some hyperlites today. It was a fairly easy install. I made a little bracket out of aluminum with tin snips to go behind the reflector under the license plate lamp. The wiring is right under the chrome cap. I just tapped into the harness that drops down from the rear brake light.. anyway, here's a pic.. pretty bright.
off
on/running
with brakes (lights flash for 5 seconds, then go solid)
2008 900 Classic (Metallic Diablo)
sickboy is offline
post #2 of 5 (permalink) Old 07-26-2009, 11:43 PM
ChevelleSSLS6's Avatar
nice! Where did you get them? How did the install go?
ChevelleSSLS6 is offline
post #3 of 5 (permalink) Old 07-26-2009, 11:52 PM
post #4 of 5 (permalink) Old 07-27-2009, 08:44 AM
vivadude's Avatar
Location: New York State, midway from NYC to Plattsburg
Increased visability is always a good thing.............
vivadude is offline
post #5 of 5 (permalink) Old 07-27-2009, 06:23 PM Thread Starter
sickboy's Avatar
I ordered them from www.hyperlites.com, super easy install. They are a little pricey as lights go, but good quality and bright.
The wiring harness from the tail light is right under the chrome cap above the license plate. There is plenty of wire to mount them wherever. I just wanted to keep it simple.. so I used some tin snips and a piece of 20 gauge aluminum to make a bracket to go behind the reflector.
It has definitely helped the tailgate factor so far.. When I hover the brake lever, people have seemed to back off more than usual.
sickboy is offline
Hyperlites VS P3 Lights? Bogie514 General Vulcan Talk 2 04-30-2012 06:40 AM
Well, installed the Scootworks pulley slaponte Engine Work 22 03-19-2011 10:18 PM
VN900 installed Saddlebags slaponte Vulcan 900 25 02-22-2009 10:19 AM
New Exhaust Installed Bigguy2468 Vulcan 1600 1 01-05-2009 02:59 PM
Tach Installed!! cs357sig Vulcan 900 12 09-24-2008 09:05 AM
