900 Kick Stand - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 02-14-2013, 07:59 PM Thread Starter
900 Kick Stand
Having a problem with my kick stand. It is hangign down enough to drag the ground on corners. This morning the spring fell off. Is this common? And is there a fix?
Thanks!!
900 Classic
herculou is offline
post #2 of 16 (permalink) Old 02-14-2013, 08:13 PM
Thanks!!
A few riders have complained that the bracket for the kickstand that is welded to the frame can come apart. I would check there first.
Sojourner is offline
post #3 of 16 (permalink) Old 02-14-2013, 08:29 PM Thread Starter
Just looked over it real good. Doesn't look like anything is cracked or bent. Bad spring myabe?
900 Classic
herculou is offline
post #4 of 16 (permalink) Old 02-15-2013, 07:43 AM
Old Syko's Avatar
You'll find the shoulder on the kickstand bolt is worn away along with the hole in the frame mounted tab being wallered out. For mine I welded up the hole in the tab and redrilled it to the proper size and replaced the bolt and nut. I also had to weld and redrill one side of the kickstand itself since the bolt actually threads into the other side of the stand. Once you have a new bolt and nut, it's a relatively simple fix that only took a few minutes. If you don't have tools, equipment and the know how to use them you'll have to find someone who does and pay their price.
Old Syko is offline
post #5 of 16 (permalink) Old 02-15-2013, 08:12 AM
ErnieC's Avatar
Just don't know how they get away with this Kawasaki. Some one could get hurt, One of them stands lets goes and falls on some one
2006 900 LT
Easy Mods
Crash Bars,Rear Tail Lights in Bags,Cooler bag on Sisy Bar,hand made Bag on Windshield,Wally world Cup Holder,Lower Shields,Gas Tank Bib,Baron Front Pulley
**Bikers are hard to find, Bikes are a Dime a Dozen**
My Second Hobby:
Here is another Hobby of mine model boats
ErnieC is offline
post #6 of 16 (permalink) Old 02-15-2013, 10:30 AM
More like the stand goes down, you're making a left turn, the bike pivots on the stand as the engine dies.
post #7 of 16 (permalink) Old 02-15-2013, 01:24 PM
Old Syko's Avatar
And don't think this can't happen. A bit over 30 years ago I was running hard and fast on a county road when the stand dropped just as I crested a hill and entered a hard left. Took out about 50 feet of woven wire fence, 3 posts and a bunch of multifloral roses. Cost me a good set of leathers, helmet, gloves and boots and left me a bloody mess. Bike was severely damaged also. You would think the stand would just pop up at first contact. Doesn't always work that way. Didn't have the stand switch back then to kill the engine but I assure you it wouldn't have mattered.
Old Syko is offline
post #8 of 16 (permalink) Old 03-03-2013, 10:25 AM Thread Starter
As luck would have it , I bought the extended warranty. Kawasaki said they would cover it. Cost me $50 deductable for the new stand, bolt, spring, and to weld / redrill hole. Good as new now, but should never have been buile like this in the first place!!
900 Classic
herculou is offline
post #9 of 16 (permalink) Old 03-03-2013, 12:48 PM
Old Syko's Avatar
Not much difference between how the stand mounts on our 900s and every other bike out there. The problem is in the materials used. Still not that big of an issue to me.
Old Syko is offline
post #10 of 16 (permalink) Old 03-03-2013, 04:51 PM
whiting57's Avatar
I have never heard of this issue with the VN either ... least it works ... i had a series of Suzuki road bikes where the stand just goes past the center angle and was prone to retracting if the bike was on a slight angle facing forward and moved slightly .. this was due to the kick stands shallow swing..
Then again, some sit on their bikes with the stand down putting another 200 lbs weight on the bracket and stand, see it all the time. Springs stretch over time and metal fatigues.
Not an iissue for me either.
whiting57 is offline
'04 V2K kick stand/ side stand biggreddtruck Vulcan 2000 6 07-10-2013 06:31 PM
Kick Stand Indicator smedlin Vulcan 2000 5 04-09-2012 10:02 AM
2005 Vulcan Classic Kick Stand, Spring & Bolt Bobh344 Bike Parts, exhausts, etc. For Sale 0 03-20-2012 08:18 PM
Problem with kick stand Toymaker Vulcan 900 10 07-25-2011 08:00 PM
Side / kick stand sansfaute Vulcan 1700 14 06-21-2010 06:00 PM
