Led cross over preventer - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 23 (permalink) Old 02-08-2013, 07:52 PM Thread Starter
Vulcar's Avatar
Hi all, I am trying to convert my signals to LED's. I find that I can put LED's in the rear and they work fine and the the indicator flashes normal. The problem is when I add LED's in the front. I have tried the load method but did not help. I found out if you have one signal indicator like the vn900 you have to add a cross over preventor circuit. The picture I attached shows it has three wires and I understand it has a couple of diodes. I want to make one but cannot locate anything on the web about how to make and how to wire it in. They are 8 bucks on online, no big deal but shipping is 7 bucks also. I was wandering if anyone can provide any information to help me build and install one of these circuits. It keeps the voltage from bleeding over I understand which may solve my problem.
Name:	Cross over pic.jpg
2007 VN900 Classic LT (Dragon Theme)
Cobra- Pipes, FI2000, Passenger Floor boards, Engine guard and luggage rack.
Memphis Shade with 9" windshield.
Mustang seat
Chrome covers for neck, radiator, Rear brake Master Cylinder, and regulator.
Kuryakan Grips
RC Components Nitro Chrome wheels w/ Night Dragon Tires.
Çobra Power Flo breather
Vulcar is offline
post #2 of 23 (permalink) Old 02-09-2013, 01:19 AM
Locate the wire loom going to the console. At a convenient spot locate the green wire and the gray wire. These are the two wires going to your indicator bulb. Cut both wires. Splice the two wires to each diode being mindful of the direction (polarity) of the diode. Twist the other end of both diodes together and splice to the gray wire going to the console. Extend the green wire coming from the console to a convenient frame ground.
Name:	diode install for turnsignals.jpg
Sojourner is offline
post #3 of 23 (permalink) Old 02-09-2013, 03:32 AM
Here's a bigger drawing
Name:	turnsignal diode install R1.jpg
post #4 of 23 (permalink) Old 02-09-2013, 07:25 AM Thread Starter
Vulcar's Avatar
LED Crossover Preventer
Wow, thank you so much Sojourner! Do you know the size of the diodes you used? Are the IN4001's OK?
As I side note I joined the "Kawasakimotorcycle.org" forum last night and found where they are actually replacing the indicator bulb with a LED type. The attachments show the final product and wiring diagram. I do not think they would mind if I shared.
The link is showing how it flashes after the Mod. Looks pretty good. I may go the LED route! http://www.youtube.com/watch?feature...&v=x3oFRJrHQ-k
Thanks again for your response. I may try your way first.
Name:	LED Preventer circuit (2).jpg
ID:	15349   Click image for larger version
Name:	LED Preventer circuit.jpg
Mustang seat
Kuryakan Grips
Vulcar is offline
post #5 of 23 (permalink) Old 02-09-2013, 08:08 AM
According to the shop manual the indicator bulb draws 2 watts so you will need to size the diodes to the bulb just to be on the safe side.
post #6 of 23 (permalink) Old 02-09-2013, 12:36 PM Thread Starter
Vulcar's Avatar
Thank you Sojourner, Good advice. Time to get my OHM's law out of the cob webs.
Mustang seat
Kuryakan Grips
Vulcar is offline
post #7 of 23 (permalink) Old 02-11-2013, 07:45 AM
madmaths's Avatar
Re: Led cross over preventer
I love the indicator led mod!!. Last summer I just remove the bulb i had no time to make the diod mod. How they make the led stay in place? Do you have the full link thanks!
Sent from my GT-I9100M using Motorcycle.com Free App
Vance and Hines Slash-Cut Staggereds.
LA Chopper intake
Cobra FI2000 PowrPro (auto tune)
Hid head light
Wrap Around LED Fork Turn Signal
Integrated Tail and Turn Signal Kit
side mount plate
HANDLEBAR SANTEE 10" STRAIGHT-UP (harley handlebars)
black exhaust wrap
Kuryakyn BLACK ISO-GRIPS
Black Spear Custom Side Mirrors
Baron 1-2`` Lowering kit
Avon 230 and 90/90
Saddlemen Renegade Solo Seat
secondary butterfly remove
madmaths is offline
post #8 of 23 (permalink) Old 02-11-2013, 08:18 AM
Banned
wiring in diode kit in speedo with bulb
wiring in diode kit in speedo with circuit board
Vulcan_tom is offline
post #9 of 23 (permalink) Old 02-11-2013, 08:22 AM
Banned
Here's where you can get the diode kit for metric cruisers
http://www.customdynamics.com/loadeq...iser_Diode_Kit
post #10 of 23 (permalink) Old 02-11-2013, 08:37 AM
Someone please explain the advantage of installing an LED for the indicator when the OEM bulb only draws 2 watts?
Shock cross over? LAF Vulcan 650 S 23 09-03-2015 11:53 AM
what year modle's cross over clifft Vulcan 1500 1 09-18-2011 09:09 AM
Cross-over pipes?? hckeynut15 Vulcan 2000 4 07-09-2011 02:31 PM
Blowing Fuse Over and Over dropzone1 Vulcan 1600 13 06-29-2011 12:11 PM
