anti-freeze - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 02-05-2013, 03:27 PM Thread Starter
anti-freeze
2008 900 Vulcan classic LT, how do you change the anti-freeze, any special kind?
GregS is offline
post #2 of 11 (permalink) Old 02-06-2013, 07:17 AM
Bear2123's Avatar
I have an 800 so I can't address the change process but can recommend the Honda coolant. It comes premixed and ready to go. Have used it for years with no problems.
Bear2123 is offline
post #3 of 11 (permalink) Old 02-06-2013, 09:56 AM
Rescue Wagon's Avatar
Anyone try a product like the one from Evans?
http://www.evanscooling.com/powerspo...ersports-blog/
2008 Vulcan 900 Custom
Cobra Dragster Pipes
Cobra Fi2000
Classic Rear Fender
Harley Tour Pack
Running on the Darkside
Rescue Wagon is offline
post #4 of 11 (permalink) Old 02-06-2013, 10:40 AM
Banned
If you have a Honda car dealership there, get a jug of the Honda Type 2 premix coolant for your bike
Vulcan_tom is offline
post #5 of 11 (permalink) Old 02-06-2013, 01:45 PM
Hockeyref's Avatar
++ on the premixed Honda coolant - works great. Do NOT use automotive coolant - it contains silicates that can potentially damage your water pump.
2006 V2K Classic LT Black/Chrome
Lots of chrome goodies, sagebrush engine guard chaps for cold days in Manitoba, Rumble Road speakers, Garmin gps, tank bib, modified seat, Ohlins rear shock - best investment ever!!, locking saddlebags, Kuryakyn luggage, brake-away cruise control, and more stuff every year.
Hockeyref is offline
post #6 of 11 (permalink) Old 02-06-2013, 03:55 PM
Jersey13's Avatar
anti-freeze
Engine ice is amazing. That or water wetter. Bike will run 10deg cooler with either of these two products. Can pick it up at cycle gear.
Jersey13 is offline
post #7 of 11 (permalink) Old 02-06-2013, 06:49 PM
tcrider's Avatar
I used the Honda Pre-mix and works great. Use the search tool on this forum, it's amazing what you can find..
I considered other products before changing the coolant, but end it up just with plain coolant. Did not wanted to risk using something wrong for the bike.
There is a drain plug under the engine, you'll have to drain the reservoir , take off the gas tank and the drain plug under the engine, which is really small. It's a very simple job and you don't have to do it very often.
Good luck
TCRIDER
08' CLASSIC 900
tcrider is offline
post #8 of 11 (permalink) Old 02-06-2013, 09:17 PM
Chas63's Avatar
I don't see anything in my Owner's Manual about that. Mine says to use ethylene glycol with rust inhibitors for aluminum engines. Prestone Antifreeze/Coolant is made of ethylene glycol and contains rust inhibitors and is safe for aluminum engines.
My Current Rides
2009 Vulcan 900 Classic LT
2005 Harley Electra Glide Classic
Chas63 is offline
post #9 of 11 (permalink) Old 02-07-2013, 12:57 PM
Vulcar's Avatar
I have used the Preston type you mention on mine and all is good as far as I can tell. The fan only comes on in very hot weather when moving in slow traffic or stopping. It is a 2007 and I have changed it three times in the 70K miles I have on it. As it notes, it is for aluminum engines and contains no silicates. Very easy to change. The plug is very small located on the bottom right side far right on the engine. Took me awhile to find it.
The service manual has a picture but still hard to identify without studying.
2007 VN900 Classic LT (Dragon Theme)
Cobra- Pipes, FI2000, Passenger Floor boards, Engine guard and luggage rack.
Memphis Shade with 9" windshield.
Mustang seat
Chrome covers for neck, radiator, Rear brake Master Cylinder, and regulator.
Kuryakan Grips
RC Components Nitro Chrome wheels w/ Night Dragon Tires.
Çobra Power Flo breather
Vulcar is offline
post #10 of 11 (permalink) Old 02-07-2013, 11:01 PM
Chas63's Avatar
70K miles. That's good to hear. I only need to put about another 60K on mine and we'll be even. Have you replaced the drive belt or done anything other than normal maintenance to it?
My Current Rides
Chas63 is offline
anti-freeze leak frets21 Vulcan 900 12 11-15-2012 04:24 PM
anti freeze change out frets21 Vulcan 900 8 10-25-2012 11:02 AM
Anti freeze dixie20j Vulcan 1700 8 08-23-2012 06:32 PM
Which anti freeze to use? bearpawh Vulcan 900 8 04-05-2011 01:42 PM
Anti Freeze Problem gbutler11 Vulcan 900 3 11-22-2009 05:30 PM
