Custom flush mount led signals - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 02-03-2013, 11:23 PM Thread Starter
After seeing the flush mount led kits available for $150 or more I decided I was going to attempt to make something on my own for much much less. This is what I came up with...
P.s don't mine the dirty garage. It's a mess with all the snow we are getting...
Name:	ImageUploadedByMO Free1359955178.787265.jpg
Name:	ImageUploadedByMO Free1359955239.431465.jpg
ID:	15261Click image for larger version
Name:	ImageUploadedByMO Free1359955249.264593.jpg
ID:	15262Click image for larger version
Name:	ImageUploadedByMO Free1359955258.831406.jpg
The best part is I did all this with 1 set of amber led strips ($20) and 2 pieces of aluminum I had laying around ($7)
I wired it to the signals and they work great. Only issue is they flash fast now so that's where I need your help...
Where and which led flasher should I get or should I just wire in resistors to solve the fast flashing?
John_rubino is offline
post #2 of 4 (permalink) Old 02-04-2013, 01:45 AM
Attachment 15260
Attachment 15261Attachment 15262Attachment 15263
cyclegear have led flasher relay for kawasaki.
14.99 and the relay is under the seat in front of the battery, you will have to open the top battery cover. unpluge the old one and plug in the new one than you are done.
2012 vulcan 900 custom
evodog is offline
post #3 of 4 (permalink) Old 02-04-2013, 03:53 AM
+1 the only way to do it.
2008 VN900C Torch Red
ISO Flame grips
230 Rear Tire
Scootworks 2" Lowering kit
Techglide Forwards
SS Braided lines
Britt Racing Exhaust
Cobra Power Flow intake X2
Avon 90/90-21 Front
Kuryakyn side mount plate
Kuryakyn LED turns amber/red
Memphis Shades Batwing w/custom speakers
Sadleman renegade solo
L&M front fender
L&M chin spoiler
Morningstar is offline
post #4 of 4 (permalink) Old 02-04-2013, 09:18 AM
I have 2 questions regarding this:
If I wanted to use a strip LED tail light AND still use my existing turn signals (splicing the LED ones into my existing ones) would that work and eliminate the need for a new LED flasher?
If I had just LED rear blinkers and stock front and installed an LED relay would the front blinkers still be okay (basically would an LED relay still support the stock front turn signals
Thanks!
momoboy is offline
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
radiator flush engine flush Brewster_440 Vulcan 800 23 02-23-2017 09:12 PM
Flush Mount Turn Signals RxStang Vulcan 900 3 06-25-2013 10:44 PM
Flush mount LED kit for the VN900 rear fender Low and Mean Vulcan 900 51 01-28-2013 11:31 AM
Flush mounted turn signals and license plate relocator bradkline Vulcan 900 25 09-21-2010 06:30 PM
