08 lt 900 wont start - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 02-03-2013, 11:46 AM Thread Starter
i have an 08 lt 900 that wont start. has new battery, turn key on and everything works as normal. push the start button and nothing. jumped it at the solenoid it turns over but wont fire. clutch switch and kickstand switch test good, any help? thanks
x1384 is offline
post #2 of 11 (permalink) Old 02-03-2013, 12:22 PM
Chas63's Avatar
When is the last time it WOULD start and what, if anything, have you done to it since then?
My Current Rides
2009 Vulcan 900 Classic LT
2005 Harley Electra Glide Classic
Chas63 is offline
post #3 of 11 (permalink) Old 02-03-2013, 12:56 PM
Do you have a meter and know how to use it?
If not, we can help there too.
Post back.
sfair is offline
post #4 of 11 (permalink) Old 02-03-2013, 03:14 PM Thread Starter
bike ran fine, it only has 1800 miles on it so i installed a new battery just to be safe and checked the charge rate, charging is 14.2v @ 3000rpm. rode home from work, stopped at the gas station to fuel up, then it would not start. i get nothing when i press the start button.
x1384 is offline
post #5 of 11 (permalink) Old 02-03-2013, 05:55 PM
Chas63's Avatar
Check the kill switch. If that's not it, then I would check the battery and the battery connections again. How did you get the bike home?
My Current Rides
Chas63 is offline
post #6 of 11 (permalink) Old 02-04-2013, 08:13 PM
Daboo311's Avatar
Swap out the battery even though charge rate is fine and see if the new one is bad.
Daboo311 is offline
post #7 of 11 (permalink) Old 02-06-2013, 07:10 PM
sounds like a wire came loose.
Bikeless and hating it.
doubleminded is offline
post #8 of 11 (permalink) Old 02-07-2013, 04:25 AM
An 08 bike with only 1800 miles?? Anyhow - yeah the battery change could be just a coincidence but it is suspicious. Is there a fuse blown maybe or the connections have worked loose after changeover?
2008 VN900 Vulcan Classic
2014 Triumph Thunderbird LT
fawlty99 is offline
post #9 of 11 (permalink) Old 02-07-2013, 07:27 AM
Chas63's Avatar
It appears that the OP just visits this site once every 6 to 9 months to post about a problem he's having with his bike and then disappears before any real resolution of the problem is revealed. Here is a quote that he made back in the summer of 2012 "i am having the same exact problem, 06 900lt, replaced stator, regulator, battery, starter relay and solenoid, starter motor still runs."
It appears that he now has a 2008 bike with similar problems. Either that or he doesn't know what year the bike really is or perhaps he never really solved his initial problems. Anyway, I'm tired of trying to help someone who won't respond to questions. Good luck. Hope you get it fixed.
My Current Rides
Chas63 is offline
post #10 of 11 (permalink) Old 02-07-2013, 10:18 AM
shawn706's Avatar
Had my bike towed home because some kid hit the kill switch on the handlebars.
shawn706 is offline
bike wont start, wont go into gear. knightrider Vulcan 800 18 07-11-2013 01:30 PM
Cheapest NOMAD in Phoenix >>>$3995<<<< louichie Bikes For Sale 1 12-08-2011 04:14 PM
1997 Vulcan classic wont start After installing radio magnusson Engine Work 10 07-20-2010 11:44 PM
Bike wont start kccbrf4 Vulcan 500 2 03-15-2009 07:50 PM
