Rear Tire Alignment - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 02-02-2013, 09:16 AM Thread Starter
MachU's Avatar
Rear Tire Alignment
I recently installed new tires on the Custom.
My concern is, how can I be 100% sure that my alignment is correct, I would hate to put premature wear on my new tires, because of a faulty alignment job.
MachU is offline
post #2 of 18 (permalink) Old 02-02-2013, 09:28 PM
Vulcar's Avatar
I go by the tracking of the belt itself. If it is centered in the pulley, I feel I am OK. Both alignment marks on the left and right side should be close to the same setting but hard to eye for final tweeking of a turn or two of the adjustment nut(s). I put mine up on a wood block to get the rear tire up off the ground. I do the adjustment, then run the bike in 1st gear to watch how the belt tracks. may take several trys but I feel good when it tracks in the center. I usually have to do the adjustment anytime the tire is changed. They always come back tracking to the left most of the time. A left turn on the right adjuster nut will cause the belt to move right. Once you are close, a very small rotation of the nuts are required for belt movement. Besure your belt tension is correct.
2007 VN900 Classic LT (Dragon Theme)
Cobra- Pipes, FI2000, Passenger Floor boards, Engine guard and luggage rack.
Memphis Shade with 9" windshield.
Mustang seat
Chrome covers for neck, radiator, Rear brake Master Cylinder, and regulator.
Kuryakan Grips
RC Components Nitro Chrome wheels w/ Night Dragon Tires.
Çobra Power Flo breather
Vulcar is offline
post #3 of 18 (permalink) Old 02-02-2013, 09:38 PM
Byron's Avatar
the best way
loosen both adjust bolts tighten the belt side to get proper belt tightness the (belt at this point will want to track to the inside) adjust the other side ever so slow untill the belt starts
to track back to left from the back of bike
i bought a laser tool it works but after adjusting the belt like above it was right on
my marks are about a 1/2 of mark off from each other so don't worry about them
Byron is offline
post #4 of 18 (permalink) Old 02-03-2013, 12:34 AM
bosco's Avatar
+1 on Adjusting based on belt tracking. I have mine set the same as when it came from the factory (about a dimes thickness gap from the left side of the pulley). The alignment marks are very close but not exact. Tire looks to be wearing normally.
2010 900 Classic
bosco is offline
post #5 of 18 (permalink) Old 02-03-2013, 08:06 AM
Rear wheel and pulley adj.
I am thinking there would be more wear on the belt and pulley than the tire if not properly aligned. This is easier to do with the stock pulley, but the OD pulley's I have seen are a bit wider than stock and take more care. This is what I encountered with my SW pulleys.
sage1965 is offline
post #6 of 18 (permalink) Old 02-03-2013, 08:51 AM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
I've replaced my rear tire twice now and I use nearly the same method as Byron. With the bike off the ground and level (on my bike jack) I snug the belt up with the left adjuster; match the alignment marks left-right; check and adjust the belt tension as needed; re-align marks; start the engine and let it idle in 1st; adjust the right adjuster until the belt tracks about 2mm from the left wall of the pulley (not everyone is comfortable with running the bike in the air. If you have any concerns, don't do it, just spin the wheel). I haven't seen any wear problems on the tires after adjusting. When I replaced the last one, the tire wear looked dead even after 14k miles.
SteveJB is offline
post #7 of 18 (permalink) Old 02-03-2013, 09:30 AM
How do you guys balance the wheels once you get the new rubber on the rim?
I hate to spend almost $100 to get a new $120 tire mounted. It is perverse, in a way...
'07 Vulcan 900 Custom, Candy Fire Red
'05 Suzuki DR-Z 400s
bass567 is offline
post #8 of 18 (permalink) Old 02-03-2013, 09:34 AM
pacomutt's Avatar
You can pick up a motorcycle wheel balancer pretty cheaply at Harbor Freight.
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #9 of 18 (permalink) Old 02-03-2013, 10:36 AM
Dyna Beads. It's the way to go. Have them in three of my bikes and have used them over and over again. Go here, www.innovativebalancing.com/ and read all about them.
Sojourner is offline
post #10 of 18 (permalink) Old 02-03-2013, 06:28 PM
bosco's Avatar
Since I have tubes, I went with Ride On Tire systems. Works really well.
2010 900 Classic
bosco is offline
Rear tire alignment Vulcanada Vulcan 800 3 05-07-2018 11:14 AM
800 classic rear wheel alignment Baronvonbombburst Vulcan 800 6 02-23-2014 10:17 AM
Rear wheel alignment team5150 Vulcan 2000 11 07-21-2013 08:16 AM
Qusetion on Measuring Rear Wheel Alignment vulcan2004 Vulcan 500 2 07-21-2011 09:11 AM
Rear fender alignment Sailor Bill Vulcan 900 1 04-24-2011 07:59 PM
