Total power saving after entire HID/LED mods - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 01-26-2013, 01:06 PM Thread Starter
Hey guys.....never seen anyone post just how much power saving they have after the LED lighting mod. so here i go.
1st: DDM Tuning HID mod.
OEM headlight: 60/55W
DDM tuning HID: 35W H4 Hi/Lo
Wattage saving: 20W( normal riding with low beam)
2nd: All 4 LED turn signal mod
OEM light bulb front: 5W running, 21W blinking x2
OEM light bulb back: 21W when blinking x2
LED light bulb front: 1W running, 2W blinking or less x2
LED light bulb back: 2W blinking or less x2
Wattage saving when:
Running:8W
blinbking:42W
3rd: LED break lights mod
OEM light bulb: 5W running, 21W braking
LED light bulb: 1W running, 2W braking
Running:4W
Braking:19W
SO in a senario lets say we just riding on highway
OEM wattage on running: 55W+5W+5W+5W=70W
LED/HID wattage on running:35W+1W+1W+1W= 38W
In another senario lets say we stop at left turn lane waitting to turn
OEM wattage with holding brake and turn signal on:
55W+21W+21W+5W+21W=123W
LED/HID wattage with holding brake and turn signal on:
35W+2W+2W+1W+2W=42W
So here is the story why i want to post this to let you guys know.
I have installed Kuryakyn battery indicator gauge, as i saw some people have the same problem as i have. what happen is you always only get one green light(13V) and sometime drop to yellow light(12V) when holding brake and turn signal on. If i rev a little bit on yellow it will turn back to green.
so guess what happen after i swap out all lights to LEDs and add HID kit.
I saw 2nd GREEN LIGHT comes on!!!! I never seen it before. I was so happey.
its up to (13V-14V), pretty sweet!! lots power so my battery will last a lot longer. I save those power for my speakers. you might have your reason for something else too. a heated something...lol
Happy modding!!
2012 vulcan 900 custom
evodog is offline
post #2 of 13 (permalink) Old 01-26-2013, 01:22 PM
kingnba6's Avatar
thanks for these details!
VROC Number: 35103
kingnba6 is offline
post #3 of 13 (permalink) Old 01-26-2013, 03:28 PM
Banned
12v 1.25amp battery tender plus will also help battery last longer
Vulcan_tom is offline
post #4 of 13 (permalink) Old 01-26-2013, 06:09 PM Thread Starter
yeah i have that, but rarley use it since i ride everyday.
I use it for my scooter since its sitting there collecting dust most of the time.
evodog is offline
post #5 of 13 (permalink) Old 01-26-2013, 07:47 PM
Vulcar's Avatar
How much cost do you have in the mods? Also can you provide the parts listing? Î would love to reduce the power drain for sure. I would think it would also allow the stator to run cooler. Thanks for the info.
2007 VN900 Classic LT (Dragon Theme)
Cobra- Pipes, FI2000, Passenger Floor boards, Engine guard and luggage rack.
Memphis Shade with 9" windshield.
Mustang seat
Chrome covers for neck, radiator, Rear brake Master Cylinder, and regulator.
Kuryakan Grips
RC Components Nitro Chrome wheels w/ Night Dragon Tires.
Çobra Power Flo breather
Vulcar is offline
post #6 of 13 (permalink) Old 01-26-2013, 10:24 PM Thread Starter
DDM Motorcycle HID Kit, 35W, H4 High / Low, 6000K
$37.50
Subtotal: $37.50
Tax: $3.00
Shipping: $13.90
Order Total: $54.40
AutoLumination.com
Rear signal LED
Bayonet
Item #: Right Angle 30led
Color: Amber, Type: 1156
$12.99 USDx2=$25.98 USD
Front signal LED
Bayonet
Color: Amber, Type: 1157
Brake LED
Bayonet
Item #: Matrix 24led
Color: Red, Type: 1157
$5.99 USDx1=$5.99 USD
Subtotal:
$57.95 USD
Shipping and handling:
$7.00 USD
Total:
$64.95 USD
LED doesnt seem very bright because i didnt get the white color LED.
if you are getting it. i will suggest you get white color LED since our light lencese are already colored. just a note.
Also you need signal relay to slow the LED blinking, i got it from cyclegears at local store for 14.99+tax, i think it was from speedmetal
also remember to take the signal indicator light out so your LEDs won't all light up and blink at the same time on all 4 signal. or you can slice the wire in the meter to put two diode kit which lot more work and i dont want to void worranty. all acc i have add on to the bike are external. I only tap into wire but never cut off wire to mod it.
Hope you got enough answers. any question let me know.
evodog is offline
post #7 of 13 (permalink) Old 01-26-2013, 10:56 PM Thread Starter
evodog is offline
post #8 of 13 (permalink) Old 01-27-2013, 07:20 AM
Banned
Here's some LED turn signal clusters
http://www.customdynamics.com/kawasa...signal_led.htm
Below is a diode kit for turn signals, the diodes prevent all 4 turn signals from flashing at the same time when using LEDs for turn signals.
http://www.customdynamics.com/loadeq...iser_Diode_Kit
Below is diagram to install diode kit if your bike has a circuit board connector in the speedo, wire colors are for 04 1500 classic.
Below is the diode kit connection with bulb with no circuit board
Here is a Standard DOT (2 wire) Flasher to bring signaling flash rate back to normal when using LEDs on 04 1500 classic, with this flasher you will lose the automatic cancel feature for the turn signal, when using LEDs for signals the flash rate will be fast to indicate to the driver there's a burnt out bulb
http://www.customdynamics.com/trick_flasher.htm
Here is a link below to the different HID bulb types
http://www.vvme.com/difference-betwe...d-bi-xenon-hid
Here's a Youtube video on the BikeMaster HID
http://www.youtube.com/watch?v=1siwy...ature=youtu.be
Here's a link to Riders Discount forum sponsor who sells the BikeMaster HID xenon Kits
https://www.vulcanforums.com/forums/s...HID+bikemaster
post #9 of 13 (permalink) Old 01-27-2013, 09:16 AM
Vulcar's Avatar
Thank you so much evodog. I will review the great info you have taking time to put together. I really appreciate the effort. Thank you also Vulcan_tom. I am well on my way to an upgrade.
Mustang seat
Kuryakan Grips
Vulcar is offline
post #10 of 13 (permalink) Old 01-27-2013, 03:02 PM
Originally Posted by Vulcar View Post
I would think it would also allow the stator to run cooler..
Stator will run at exactly the same temperature.
sfair is offline
Total power loss. cajuncountry Vulcan 1600 23 07-19-2014 02:56 PM
Raining the entire week off and on in Michigan RoninSpecter General Vulcan Talk 3 05-22-2014 01:30 PM
entire rear fender section from 96 500 Vulcan xskater2099 Bike Parts, exhausts, etc. For Sale 0 08-02-2013 04:58 PM
Total Power Loss carthadys Vulcan 800 18 03-09-2012 10:23 AM
Should I fill up the entire crankcase with lube oil during winter storage? Vulcan500LTD-Canuck Oil and Lubrication 7 12-16-2010 03:26 PM
