No fast iddle - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 01-20-2013, 10:42 PM Thread Starter
No fast iddle
Today when I started the bike this morning for the first time, i noticed there was no fast iddle, it normally starts with a fastiddle for a minute or two.
This is not the first time this happens, but it is not always.
Does this happens to anyone else, do you know what could this be?
Aleco is offline
post #2 of 7 (permalink) Old 01-21-2013, 06:11 AM
Since you are in Panama, do you notice a difference on days that are especially warm (even for Panama)? Might relative humidity also affect the ECM's reading of the atmosphere?
2008 VN900 Custom
crazyj is offline
post #3 of 7 (permalink) Old 01-21-2013, 09:09 AM Thread Starter
To tell you the truth, I did not comsider weather conditions.
Right now we are on the dry season, and it happened yesterday, but it also happened a few weeks ago when it was raining a lot, like tropical rain forest type of rain.
I'll be paying attention to the temps, bc on this season it is 22C in the mornings, in the afternoons it can get up to 36-38,39, sometimes 40-41, with a relative humidity of 68%, during the rainy humidity is inthe high 90's pretty much all the time
Aleco is offline
post #4 of 7 (permalink) Old 01-22-2013, 07:54 AM
Just a couple of questions. How old is your bike? When was the last time you changed plugs? What RPM does the bike idle at after it's warmed up? How would you rate the engine speed when it does start with a fast idle?
Sojourner is offline
post #5 of 7 (permalink) Old 01-22-2013, 01:31 PM Thread Starter
My bike is from 2009, Splugs never been changed just yet. The rpms i gues is less than 1k/min, I'm actually not sure on the nomenclature, but it is normal after the it is warmed up. Whet it starts with the fast idle is faster than normal but not too fast, i cild say is normal fast idle comparing what I hqve seen around.
Aleco is offline
post #6 of 7 (permalink) Old 01-22-2013, 06:58 PM
I think sfair would agree that changing the plugs would be a good start. Next, the cold start idle can be adjusted without touching your normal idle adjustment. You will have to remove the air cleaner assembly to get at the throttle body. There's a screw on the pulley that the throttle cables are attached to that can be turned counter clockwise (turned out) to increase the cold start idle speed. You will need to have someone hold the throttle wide open to access this screw.
post #7 of 7 (permalink) Old 01-23-2013, 05:32 PM Thread Starter
Thanks a lot, I'll look into that.
Aleco is offline
no go....then go real fast..then no go mercman Vulcan 500 18 06-10-2016 08:08 PM
No start, no indicator lights, no sound Logickle Vulcan 500 21 07-22-2015 07:41 AM
black smoke at iddle goualon69 Vulcan 800 2 07-23-2012 06:01 AM
No fast idle?! Luciferiad Vulcan 900 4 06-30-2011 07:27 PM
600 mi service done & now no more fast idle at start up?? Swatcop Vulcan 900 5 05-22-2011 12:03 PM
