900 Speedometer fix? - Kawasaki Vulcan Forum : Vulcan Forums
LinkBack Thread Tools
Old 01-20-2013, 01:07 AM Thread Starter
bosco's Avatar
Tried to do a search, with no success (unless it buried inside another thread), but was looking to see if there is a fix for the 900 speedometer? Like a change in resistor like the fuel gauge fix. I can always just add in the extra miles. With my current set up my speedo reads 65mph (actual speed 70mph).
Thought if it's easy, would tackle a new project.
2010 900 Classic
bosco is offline
Old 01-20-2013, 06:46 AM
Hmmm, that's opposite of my speedo (reads 70, actual 65)...
leonardgray is offline
Old 01-20-2013, 10:08 AM
Collinba's Avatar
Not surprizing. I seem to recall from previous posts that bosco has both the front and rear overdrive pulleys installed. I have the front pulley installed and the speedo is bang on. Bosco, I thknk the only fix is to install a speedo turner kit - there are a number of them available. Here is one https://www.vulcanforums.com/forums/s...ad.php?t=11839
2010 Classic LT
Collinba is offline
Old 01-20-2013, 10:22 AM
Strompilot's Avatar
Try this website. The Speedohealer is a popular item for motorcyclists to make your speedometer accurate.
http://www.healtech-electronics.com/
'09 650 VStrom
Strompilot is offline
Old 01-20-2013, 12:12 PM
V-Rider's Avatar
Front & rear pully change and or a 200 rear tire. These seem to be the most common fixes. A combination of all 3 may be overkill though, not too sure. These are mainly done to bring the cruising rpm range into a little more comfortable range but it also corrects the speedo error.
Scan
2008 VN900 Classic LT
V-Rider is offline
Old 01-20-2013, 10:39 PM Thread Starter
bosco's Avatar
Guys, Thanks... This is what I was looking for. I do have both pulleys and it swung the speedo the other way (65 shown, 70 actual). I will be looking into the speedo tuning. Appreciate all the info.
2010 900 Classic
bosco is offline
Old 01-21-2013, 05:43 AM
rick's Avatar
Curious. Where does the speedo read from on the 900s? On the 800s its at the wheel, rear on customs and classics, front on drifters I believe. Is it from the trans?
2005 800 classic
2012 Voyager ABS
rick is offline
Old 01-21-2013, 04:00 PM
Collinba's Avatar
Speed sensor is on the crankcase (left side). It measures crank speed, sends a signal to the ECU which generates an OEM calibrated signal for the speedo that includes correction for OEM gear and pullys and OEM tires. That's why front and rear pulley changes or tire size changes create a descrepency between indicated and actual speed.
2010 Classic LT
Collinba is offline
Old 01-21-2013, 06:07 PM
rick's Avatar
Thanks. That makes sence then.
rick is offline
Speedometer fix Gunner357 Vulcan 900 9 08-12-2016 05:50 PM
800 speedometer fix ? gearhead351w Wrench Heads 2 06-02-2015 12:33 PM
Kawasaki 900 Classic Gas gage fix j6320 Southeast 3 09-21-2012 10:32 AM
Cheap Speedometer Fix bouson Vulcan 900 1 07-17-2011 09:01 AM
Speedometer Fix Akgeezer Vulcan 900 15 10-22-2010 11:02 AM
