Efi - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-08-2009, 10:02 AM Thread Starter
Efi
Anyone else experiencing an issue where the EFI (warmup idle) is staying engaged for long periods of time. Even after my bike is warmed up, if I turn it off for say 10 minutes and start it back up the EFI (high idle) stays on for a couple minutes?
Khgiese
2009 Vulcan 900 Classic LT
khgiese is offline
post #2 of 7 (permalink) Old 07-08-2009, 10:27 AM
Pretzel's Avatar
Aye, at times. It's just like the EFI cars... sometimes, if ya just blip the throttle, it will settle into a normal idle.
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #3 of 7 (permalink) Old 07-08-2009, 10:43 AM
silenthill's Avatar
What a coincidence! I was just going to make a thread. The last two days my idle hasn't been going into warm-up. I start the bike, wait for it to "idle down" and it doesn't happen. It appears(sounds like) it is already on regular idle. Should i turn the idle adjustment up?
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #4 of 7 (permalink) Old 07-08-2009, 06:28 PM
i sometimes have to give the throttle a lil twist to make mine to go into high idle at startup
08 900 classic
nyokie is offline
post #5 of 7 (permalink) Old 07-08-2009, 09:39 PM
I had the same thing happen to me this week. had to give a little throttle twist to get into start up rev. Adjusting the idle sounds like a good idea, I'll try it and see.
Kgreen is offline
post #6 of 7 (permalink) Old 07-09-2009, 04:52 AM
1945's Avatar
Just another annoying quirk of the bike. It's been suggested that you can twist the throttle backward when starting and the idle be normal. Haven't tried it since I haven't looked in the service manual to see what could break if I repeatedly performed that act.
1945 is offline
post #7 of 7 (permalink) Old 07-09-2009, 08:29 AM Thread Starter
Burping the throttle does little good other then to rev up the engine. I have tried burping the throttle several times and it does not help.
I took it to the Dealer I bought it from, but after watching his "mechanic" work, I doubt they will be able to fix or even know how to fix this.
I adjusted the idle screw but that leaves me with a warmed up idle to low.
I think I may need to take it in to a shop and have it Dyno tested and adjusted.
Khgiese
khgiese is offline
Winterizing an EFI bike BikerDave8756 Vulcan 1500 1 09-28-2009 09:39 AM
EFI light frets21 Vulcan 900 9 09-06-2009 11:34 AM
New 1500 Classic EFI owner TCWJoe New Member Introductions 2 02-14-2009 04:24 PM
wire diagram for vulcan 1500N efi year 2000 coloradobikersaruba Vulcan 1500 2 09-20-2008 06:35 PM
