Wolo Horn Mishap - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 28 (permalink) Old 10-24-2012, 07:58 PM Thread Starter
Wolo Horn Mishap
I installed a Wolo bad boy horn in the stock location. I went over a hard bump slowly and bottomed out the front suspension. It forced the horn into the front fender and put a 3in split in the fender and messed up the paint. It's gonna set me back $250 to get the fender fixed and painted. Anyone have a good location for an air horn or other mounting advice?
Thanks in advance.
Brandon
Brichm03 is offline
post #2 of 28 (permalink) Old 10-24-2012, 08:35 PM
That sucks.
Some people have put their horns underneath the side covers but I wasn't that crafty so I put mine by the shifter.
Graybush is offline
post #3 of 28 (permalink) Old 10-25-2012, 06:33 AM
Bear2123's Avatar
Mounted mine to the brake side, lower radiator shroud mounting bolt.
Bear2123 is offline
post #4 of 28 (permalink) Old 10-25-2012, 07:24 AM
Just like Graybush, mine is on the left side frametube, however higher up by the top of the Rad. I would be concerned with it being down lower, because my left foot and horn could try to share the same space. The relay is higher again on the frametube to keep it out of the weather as much as possible. Sorry to hear about your bike.
2009, 900 Vulcan LT Classic
Modifications
Modulating Headlight
Flashing Tail Light
Wolo Bad Boy Air Horn
Kick-back Risers
Custom GPS Holder
Papa Smrph is offline
post #5 of 28 (permalink) Old 10-25-2012, 11:51 AM Thread Starter
Solved!!!
Thank you for your suggestions. I bought a Stanley metal bracket, and longer bolts and mounted it on the left side. My wires reached and the horn is a safe distance from the ground. Not a 10 in the beauty department, but it turned out ok.
Brichm03 is offline
post #6 of 28 (permalink) Old 10-27-2012, 05:10 AM
Mounting of Bad Boy
I mounted my chrome bad boy to the Cobra Crash bar using a chrome Kuryakyn P-Clamp. Looks and sounds great !
brianinkanata is offline
post #7 of 28 (permalink) Old 10-27-2012, 09:44 AM
oldrider's Avatar
Question stock wiring ?
Thanks in advance.
Brandon
Don't mean to hijack the thread, but I was wondering if you went to a heavier wire size and fuse? I've had one on the shop shelf for several years, because when I mounted it, it would blow the 10A fuse. That to me, indicated that it needed a heavier fuse, which also means heavier wires needed, at least I would think that would be the case. I didn't want to go to the hassle of rewiring just for the horn, which I think involved lifting the tank to do the job.
Oldrider
oldrider is offline
post #8 of 28 (permalink) Old 10-27-2012, 10:54 AM Thread Starter
Re: Wiring
I used the wiring kit that Wolo sells with a relay and it works great.
Brichm03 is offline
post #9 of 28 (permalink) Old 10-27-2012, 12:23 PM
Oldrider
Use a relay and you will not have this problem. I mounted mine on the brake side like brianinkanata. Works excellent.
Brian
'09 900 Kawasaki Vulcan Classic LT, titanium/white, tach, Kawasaki light bar, CTEK battery maintainer, Powerlet outlets for GPS, cell phone, etc. Mustang touring seat.
Eastern Beaver headlamp/driving lamp relay kit. Eastern Beaver 3CS fused accessory circuits. Matazu
luggage rack. LED bulbs, Rumble LED turn signal relay, Grote LED driving lamps installed in oem driving light housings. Michelin Commander II tires. Laconia luggage bag by T BAGS.
Brian C is offline
post #10 of 28 (permalink) Old 10-27-2012, 01:02 PM
oldrider's Avatar
relay
http://www.amazon.com/gp/product/B00...ls_o00_s00_i01
I didn't use the relay, just hooked it up to the original wires. I do have the relay on the shelf too Guess I'll have to give that a try.
Oldrider
oldrider is offline
WOLO horn J&P Cycle 360-102 02, $50, installed today Clumpster Vulcan 900 2 01-07-2012 08:45 PM
Wolo Air Horn BlAzE94 Vulcan 900 12 01-03-2012 02:58 PM
Mounting a Wolo Air Splitter Horn KEWOOSKI General Vulcan Talk 0 11-15-2011 08:14 AM
Wolo horn eat your heart out Jace Bror Vulcan 900 1 11-03-2011 04:42 PM
wolo badboy horn mag246 General Vulcan Talk 15 10-30-2011 08:36 AM
