Worn out kickstand! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 10-10-2012, 07:25 PM Thread Starter
Old Syko's Avatar
Worn out kickstand!
Is this common? Stand would sag to the point of engaging the stand switch which shuts down the engine when in gear. The bolt was worn way down. The stand was worn down on the inside. Even the frame tab was worn off really bad. Took everything apart. Welded up all effected parts and reground them to proper tolerances and reassembled them with a good amount of marine grade heavy grease and a new bolt and lock nut. Took about 45 minutes to fix but the whole time I was wondering what others who don't have the tools to work with do. I would hate to think what a dealer would do.
BTW this is an 07 that had 13,000 on it when I got it. I put over 4,000 on it in less than 8 weeks so I may well never have this problem again.
Old Syko is offline
post #2 of 11 (permalink) Old 10-11-2012, 10:23 AM
Color: Orange SE
That's wild. Mine has 20,000 on it and the kickstand works like new. Spray a little grease in there once in a while. Still pops back up into place!
Is it possible yours got damaged somehow, rather than worn?
Romans5.8 is offline
post #3 of 11 (permalink) Old 10-11-2012, 11:43 AM Thread Starter
Old Syko's Avatar
No damage. Just literally worn out. Even the bolt hole was elongated half again more than normal.
Old Syko is offline
post #4 of 11 (permalink) Old 10-11-2012, 12:06 PM
pacomutt's Avatar
Strictly lack of lube, I would suspect. Keep the pressure washer away from there too.
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #5 of 11 (permalink) Old 10-11-2012, 12:13 PM
Color: Orange SE
Just curious, but what all should be lubed? I hit it with a shot of grease when it doesn't "spring into action", anything else? I just spray it I don't take anything apart or anything.
post #6 of 11 (permalink) Old 10-11-2012, 12:34 PM
CRUISERDON's Avatar
No grease, Loose hardware, lots of vibration !
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #7 of 11 (permalink) Old 10-11-2012, 02:44 PM
Hot Cruiser's Avatar
When servicing my '07 900 I oil the stand pivot bolt area and work the oil into the bolt, wiping off the excess, and apply grease to the spring ends at their attachment points. Everything still works as when new.
Hot Cruiser is offline
post #8 of 11 (permalink) Old 10-11-2012, 05:44 PM Thread Starter
Old Syko's Avatar
In retrospect this is a rather common issue and not just with 900s or even Kawasaki but with a lot of different bikes. Found old threads on this very forum dealing with this same subject. Seems to be common practice to drill the tab oversize and sleeve a new bolt. Sounds like a Mickey Mouse way to fix a symptom to me rather than fix the whole problem. I would suggest everyone pick up an aerosol can of marine grade lithium (or the lube of their choice) and give the stand a shot anytime they think about it just to avoid future problems.
Pacomutt mentions not to use a pressure washer. Good Lord! I can't imagine the effects of that but I'm willing to bet the kickstand would be the least of your worries after that.
Old Syko is offline
post #9 of 11 (permalink) Old 10-16-2012, 06:49 PM
Das Disco's Avatar
Hey there! I just finished reading through and believe i might be having the same issue.
I am not a welder but i have a buddy who has a machine shop. Do you think its wise to take it to a dealer to have the repair made or should i see if my buddy can make the repairs?
I have tools just not a welder...
Das Disco is offline
post #10 of 11 (permalink) Old 10-16-2012, 07:03 PM
pcarrell's Avatar
Interesting! I have 45,000 miles on my ride and no problems. Since the Drifter uses a Classic frame for the most part, I hind this curious.
Philip
BOTM Winner, February 2010, December 2012, August 2014
Third Place BOTY 2012
Third Place BOTY 2014
pcarrell is offline
Worn Kickstand MickeyNew Vulcan 1600 4 06-09-2016 10:36 AM
Michelin Commander 2 front tire worn out! Wild Bill Vulcan 900 8 06-07-2016 08:51 AM
Carb trouble...too worn out to fix? Blue_97 General Vulcan Talk 5 12-12-2012 04:18 PM
Are these tires worn out? >_> Leaf Wheels and Tires 6 09-28-2011 03:21 AM
worn carbs colinken Vulcan 1500 0 03-29-2011 02:54 AM
