Custom belts and barons pulley - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 09-11-2019, 04:00 AM Thread Starter
Year/Make/Model: 2012 Vulcan 900 custom
Displacement/CC's: 900
Color: orange/black
Question Custom belts and barons pulley and 230 avon
Hi guys.
Trying to find info about belt and pulley on our bikes because im using 230 avon tyre and want do pulley swap to Barons
230 avon tyre dont have enough clearence to mudguard and we need trim it.
If i try use front pulley by Baron it has bigger diameter and, if i calculate right, would shift rear wheel to front by 4.4mm. Thats impossible.
If we get jus rear pulley by Baron (damn, expensive thing) rear wheel will move 9mm to the rear.
So if we combine 2 pulleys we will shift rear wheel y 4.5mm rear.
Thats good, but expensive rear pulley makes thing bad, and dont solve problem with trimming mudguard.
So solution is to get custom belts.
Stock is 14m 153 tooth belt. Profile seems like HTD.
I found 1 supplier in China (yeah, China, but i work with them before, good belts, really).
They can do 20mm width 14mm pitch HTD belt with fiberglass reinforce in 154, 156 and 157 teeth.
Belt would cost only 32$
With biggest 157T belt and both pulley rear wheel would come back for 33mm!
There would be enogh clearence for mudguard, little bigger wheelbase and possibility to swap pulleys.
Any toughts?
Maeg is offline
post #2 of 3 (permalink) Old 09-12-2019, 03:39 AM
jbiggers's Avatar
Year/Make/Model: 2013 Vulcan 900 Classic LT
Color: Sparkle Black and Titanium
About the only thing I could suggest is to look at the Gates website and see if there is a similar belt available in the length (number of teeth) you need. Gates is an alternative source for the standard drive belt for the VN900, though I hear it is slightly narrower than the factory belt. The cost of the standard belt from Gates is about $70 or so.
jbiggers is offline
post #3 of 3 (permalink) Old 09-12-2019, 04:43 AM Thread Starter
Color: orange/black
No. Gates, Continental, Goodyear dont produce such belts. Only 150, 160, 165. Very strange size Kawa choose for our bikes.
I dont worry about belt. It will be okay.
I worry about shifting rear wheel. Checked at home - 33mm is cannot be done.
Best, as i see - 156T belt, shifts rear wheel by 21mm rear. If i combine it with front Barons pulley, that gave me 5mm shift to Front - it will be about 16mm shifting to the rear.
Front pulley plus biggest 230 tyre - i think it will be good in engines rpm for cruising in town and highway about 100-100 km/h max.
Maeg is offline
