2006 Wont shift out of first - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By westcoastkevin
post #1 of 8 (permalink) Old 08-11-2019, 06:42 PM Thread Starter
Year/Make/Model: 2006 Vulcan 900B
Displacement/CC's: 900
Color: Metallic Blue
Cool 2006 Wont shift out of first
Stopped at favorite Dunkin Donuts this morning, when I came back out to the bike it would try to lurch forward when attempting to start with clutch lever fully pulled in.
I'm guessing the Clutch assembly or actuating arm is damaged versus the shift mechanism which will go in and out of first to neutral and back. She limped home in first gear but would not upshift to second. Attempts to shift just produced an unpleasant sound from the gearbox but not like metal on metal - more of a "nope, not shifting" whine.
What say you? Start with the clutch assembly and actuator?
twhite47 is offline
post #2 of 8 (permalink) Old 08-11-2019, 08:20 PM
G Man's Avatar
Color: Red
I remember reading on here somewhere that someone had the clutch linkage go, they suspected from hitting the heal shifter too hard over time. Do a search, sounds like a similar issue.
Gone are the days we stop to decide where we should go, we just ride.
G Man is online now
post #3 of 8 (permalink) Old 08-11-2019, 08:44 PM Thread Starter
If it was heel shifting that they suspected, wouldn't it be the shift mechanism that took the abuse? I'll do the search as you suggested though. thanks!
twhite47 is offline
post #4 of 8 (permalink) Old 08-12-2019, 10:37 AM
Hot Cruiser's Avatar
Hitting the heel shifter or the toe shift lever too hard (like stomping on it) can actually bend the transmission shifter forks. Hopefully that isn't the issue here - requires splitting the engine casings to repair.
Jesus is Lord
Hot Cruiser is offline
post #5 of 8 (permalink) Old 08-12-2019, 11:34 AM
Year/Make/Model: 2008 V900 Custom
EDITED:
When does the noise happen? Does it happen when you pull the clutch in?
Here is a test to do.
Given that pulling the clutch lever is not required for shifting while moving, you should be able to get through the gears just using the throttle and the shifter.
If you can change gears the problem might be clutch linkages.
If you can not change gears, then the problem might be shift forks or stem rod or linkages
https://www.bikebandit.com/oem-parts...8882#sch549396
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is offline
post #6 of 8 (permalink) Old 08-12-2019, 05:04 PM
Originally Posted by westcoastkevin View Post
EDITED:
Shifting gears without using the clutch can place heavy and repeated heavy loads upon the gearbox which in turn can lead to premature transmission and gearbox failure. Having noted that, with my previous bike I sometimes changed gears without using the clutch in heavy commute traffic and still had no related problem.
Jesus is Lord
post #7 of 8 (permalink) Old 08-13-2019, 11:39 AM
It is like anything else, you have to practice to become proficient with it. I grew up on equipment with crash gearboxes. When you are proficient at rev matching and changing when off the throttle momentarily, you can slip in and out of the gears easily. Of course it is easier in the 3-4-5 range and requires more practice and better throttle control when down in 2-1 but it is still a skill that can be learned.
Anyway, I do not have any interest in who does it or not. I only meant to say that the technique could be useful right now for the OP to see if he/she can get through the gears.
Good luck to the OP with the problem.
wolfy(TM) likes this.
PERFORMANCE:
Barons BAK intake
COMFORT:
Kuryakn ISO Grips
MISC:
Cobra Crash Bar
post #8 of 8 (permalink) Old 08-13-2019, 01:21 PM Thread Starter
No. I actually tried the powershifting on the way home limping along in 1st gear - no soap. It seems to me that the overriding factor is that the bike would not move forward or backward with the clutch lever fully pulled in. It was only by repeated rocking back and forth that I finally was able to get her into neutral, start the bike, shift back to first and then 35 mph all the way home....
That, to me, smells like an internal clutch problem.
Once I made it back to the house, as soon as I came to a stop, with the clutch lever full in, she stalled and went back to the not wanting to roll either direction. Oil level looks good but is due for a change. Could have sworn I heard a rattle from the gearbox when I first started out that morning - maybe a broken clutch spring?
twhite47 is offline
