2014 VN900 tail light problem - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By whoaru99
post #1 of 7 (permalink) Old 08-01-2019, 12:05 PM Thread Starter
Year/Make/Model: 2014 Volcan 900 LT
Displacement/CC's: 900
Color: Black/Silver
Hi all,
I recently bought this bike a couple of months ago and have really enjoyed it. The brake light works correctly but I noticed the other day that the turn signal/tail lights don't work correctly. The left and right rear blinkers both blink correctly but neither side has running lights. I changed both bulbs and both still blink correctly but still no running lights. I also checked the fuses under the seat and they were ok. When I originally bought the bike, the left blinker blinked really fast but at some point went back to normal. Any ideas what it might be? Thanks.
GhostRider32 is online now
post #2 of 7 (permalink) Old 08-01-2019, 12:14 PM
whoaru99's Avatar
When you replaced the lamps did you put back the same type that you took out?
Or, did you first confirm the installed type vs. the correct type to make sure the proper lamps are installed?
durox likes this.
whoaru99 is offline
post #3 of 7 (permalink) Old 08-01-2019, 01:44 PM
durox's Avatar
Year/Make/Model: 09/Vulcan900/Custom SE
@GhostRider32
I think the rear turn signal lamps do not have running lights. Only the front signal lamps do, unless it's an upgrade..
The running light is in the taillight/brake lamp (+license plate light)
The light bulbs for the front and rear turn signal lamps are different, the front bulbs are a two filament type but the rears are single filament bulbs:
Rear: BA15S base for rear turn signal [1156 bulb],
BAY15D base for tail/brake [1157/2397 bulb]
Front: BAY15D base for front turn signal [1157/2397 bulb]
were both front and back left blinkers fast simultaneously? Usually either the front or back turn signal bulb is not working when you get a fast blinking...
If you re-experience fast blinking, after light bulb and fuse checks, inspect the sockets. It's a sliding contact plate with a spring underneath that pushes the contacts against the bulb's base. that sliding mechanism can get stuck because of whatever reasons. clean the sockets and apply small amount of dielectric grease pushing in the contact plate... make sure you can push it in without much pressure.. watch for the offset pins on the light bulbs.
there are a few discussions about the lights, this is on of them: https://www.vulcanforums.com/forums/...-signal-3.html
durox is offline
post #4 of 7 (permalink) Old 08-02-2019, 03:20 PM
Year/Make/Model: 2008 V900 Custom
The rear turn signals on the 900 do NOT serve as running lights. Only the fronts.
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is online now
post #5 of 7 (permalink) Old 08-02-2019, 04:45 PM
Bike Of The Fall Winner 2017
GFISH's Avatar
Year/Make/Model: 2006 Vulcan 900 Classic
Displacement/CC's: 903
Color: Silver
no rear running lights. Orange is not legal. if you want them to be running lights you have to rewire and change to red.
"As long as I have the voices in my head, I'll never ride alone."
2006 Vulcan 900 classic
Mustang Day Tripper seat
Cobra Light Bar
Cobra Air Scoop
Cobra short sissy bar
Cobra Lowers
Baron's front and rear pulley
Baron's Big and Nasty pipes
Leatherlyke hard bags
Blue Superbrites LED accent lights
Chrome Woo Loo Air Horn
Avon Grips
GFISH is offline
post #6 of 7 (permalink) Old 08-02-2019, 09:38 PM Thread Starter
Color: Black/Silver
DOH..... I didn't realize that they were not running lights. I did replace them with Sylvania Long Life 1156's though.
Thanks all for each detailed response. This is an awesome forum. Hopefully someday I can pay some knowledge forward to help someone else.
post #7 of 7 (permalink) Old 08-14-2019, 01:08 AM
Year/Make/Model: 2009 Kawasaki Vulcan 900 Classic
Color: Black
Look at custom dynamics for LED taillight running lights/blinkers
BigRoy1387 is offline
