oil change and screen(?) - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 12 (permalink) Old 07-30-2019, 10:28 PM Thread Starter
JCC
Year/Make/Model: 2006/Kawasaki/Vulcan VU900B
Displacement/CC's: 900
Color: blue
Does my '06 900 have the screen that has to be checked and cleaned at oil change? Does my wife's '08 500? Thank you.
Sent from my SM-N950U using Tapatalk
JCC is offline
post #2 of 12 (permalink) Old 07-31-2019, 10:31 AM
durox's Avatar
Year/Make/Model: 09/Vulcan900/Custom SE
@JCC
the manual recommends cleaning the oil screen with high-flush solvent when the oil is changed (it is mentioned that gasoline and low-flash solvents are not to be used) and also replace the O-ring.
most of us don't clean the oil screen every oil change (most of the time it's clean) and also the O-ring is reusable...
when you take out and reinsert the oil screen, you will need to bend it a little in order to clear the frame... make sure the components go in in proper order (use finger to fish out and reinsert the oil screen).
don't over tighten it, torque it to 20Nm, 15ft lb
here's a diagram:
https://www.partzilla.com/catalog/ka...d6f/oil-filter
have fun, be safe.
durox is offline
post #3 of 12 (permalink) Old 07-31-2019, 10:54 AM Thread Starter
JCC
Color: blue
Thank you! Is the screen in the same place as the drain plug? Is there a screen on the '08 Vulcan 500 as well as '06 Vulcan 900?
JCC is offline
post #4 of 12 (permalink) Old 07-31-2019, 11:41 AM
durox's Avatar
the oil screen is not close to the drain plug. it's lower mid engine, left side.
for locating the oil screen, consult the above link and look for the part 11012.
This forum has different sections. for questions related to the Vulcan 500 you'd have better chances for replies by posting your questions in that section: https://www.vulcanforums.com/forums/50-vulcan-500/
durox is offline
post #5 of 12 (permalink) Old 07-31-2019, 11:42 AM
Hot Cruiser's Avatar
Unless I have totally missed it my '07 Kawi manual does not mention the oil screen in the section regarding oil changes, so apparently the manual was changed for later years. I found out about the screen from being on Kawi forums. In any event I have had mine out only twice - once after the first two oil changes and once after I replaced my stator. Both times the screen was clean, and I haven't bothered otherwise since as durox mentions it has to be bent slightly to remove and insert it and I feel that I am much more likely to damage it by repeated bending than cleaning a clean screen would accomplish.
durox likes this.
Jesus is Lord
Hot Cruiser is offline
post #6 of 12 (permalink) Old 07-31-2019, 11:54 AM
durox's Avatar
@Hot Cruiser
I forgot to mention that I was referring to the service manual, I'm pretty sure the owner's manual does not instruct in cleaning the oil screen filter...
I've found some small pieces of silicon from the liquid gaskets they use -when the engine was young... it does seem that one could damage that oil screen with frequent bending. it's about $10 and not everybody has it..
durox is offline
post #7 of 12 (permalink) Old 07-31-2019, 12:10 PM Thread Starter
JCC
Color: blue
Would the liquid gaskets be for the o-rings? I saw someone on YouTube was spraying the screen with brake cleaner to clean it.
JCC is offline
post #8 of 12 (permalink) Old 07-31-2019, 12:14 PM Thread Starter
JCC
Color: blue
Also, I may go with 15w-30 4-stroke oil. Have been told that is better for summer.
JCC is offline
post #9 of 12 (permalink) Old 07-31-2019, 04:11 PM
durox's Avatar
@JCC
brake cleaner would work. in essence you want to clean the screen of the large particles it collects. there is no need to degrease it. you'll see what I'm talking about when you take it out... a firm shake or a shop rag does the job in most cases.
there is no need for liquid gaskets. only the factory uses it when assembling the engine. some excess material gets loose after the first miles and the oil screen captures all that...
regarding the motor oil, the vulcan900 requires a heavier than 30 oil for the summer (depending on the temperatures)... from 10F - 110F temperature, use 10W-40 oil.
a 10w-30 oil is to be used from 10F to 85F.
*search on google for both the owner's manual and service manual. you'll find them both in pdf form for free and you'll find everything you need to know and more about the vulcan 900.
durox is offline
post #10 of 12 (permalink) Old 07-31-2019, 05:32 PM
Year/Make/Model: 2008 V900 Custom
Originally Posted by durox View Post
the manual recommends cleaning the oil screen with high-flash solvent when the oil is changed (it is mentioned that gasoline and low-flash solvents are not to be used)
This is more of a fire safety thing than anything. That kind of warning appears a lot in the books.
durox likes this.
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is online now
