Vn900 issues - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 07-30-2019, 01:10 PM Thread Starter
mahtaa's Avatar
Year/Make/Model: 1995 EN500-B1
Displacement/CC's: 500
Color: Green/White
Vn900 issues
Hi, recently got a 2009 vn900, 50k on the clock , full dealer service history, well looked after. Today suddenly no charge in the battery. Bump started and carried on riding, then had intermittent speedo. Can’t really see that they are related. Half hour later the indicators were flashing week...isn’t the alternator or such like supposed to put out enough volts / amps to power the electric circuit and charge the battery? No light on the instrument panel and I have no manual. Hopefully a dead battery or loose connection. Any advice welcome cheers
mahtaa is offline
post #2 of 8 (permalink) Old 07-30-2019, 02:18 PM
March411's Avatar
Year/Make/Model: 2019 Vulcan Classic
Displacement/CC's: 903
Color: Metallic Matte Graphite Gray/Metallic Matte Carbon Gray
Link to download your manual:
https://ownersmanuals2.com/kawasaki/...s-manual-68823
Only a biker knows why a dog sticks his head out of a car window
March411 is offline
post #3 of 8 (permalink) Old 07-30-2019, 02:40 PM
Color: Black / grey
Yep engine SHOULD charge the battery and keep you going unless the charging system goes bad then your battery dies and your stranded.
BUT you were able to push start right?
If you have the repairs history look to see if the stator has been replaced.
BUT first find how old the battery is, if 3 years or more go get a new one.
vulcandoc is offline
post #4 of 8 (permalink) Old 07-31-2019, 09:24 AM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
You can also go directly to kawasaki.com and download the owners manual free.
Jeff, Twin Cities, MN
MN-Rider is offline
post #5 of 8 (permalink) Old 07-31-2019, 12:52 PM Thread Starter
mahtaa's Avatar
Color: Green/White
Great thanks. Replaced battery as old was many years old. 11.6 volts didn’t even crank the engine. Surprised! New battery at 12.6v, on idle at 12.2, reviving engine made no difference do I guess I have a charging issue. I want to check the stator for grounding issues but I can’t find the damn connector with the three white wires!
mahtaa is offline
post #6 of 8 (permalink) Old 07-31-2019, 01:32 PM Thread Starter
mahtaa's Avatar
Color: Green/White
So found the plug...under the radiator. Full of oil, cleaned it, no short to earth on any wire. Then started bike and tested voltage between each white wire and earth. All different but one reading was 3.6v when voltmeter was set to 20v, so 72v then ??
mahtaa is offline
post #7 of 8 (permalink) Old 07-31-2019, 01:51 PM Thread Starter
mahtaa's Avatar
Color: Green/White
Correction; ohmmeter shows 0.03 when Leads touch each other so basically shorted out. Each white stator wire shows 0.03 between it and negative post on battery. So all three are sorted or it just takes one? Or my meter is shite????
mahtaa is offline
post #8 of 8 (permalink) Old 07-31-2019, 01:52 PM Thread Starter
mahtaa's Avatar
Color: Green/White
Shorted not sorted
mahtaa is offline
