Vulcan 900 Classic Pegs - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 07-26-2019, 07:55 PM Thread Starter
Boomer914's Avatar
Does anyone know (or have tried) if you can replace the floorboards for pegs on the the 900 classic? Hit them corners yah!
Never give up,
Never give in,
Passion is all you need,
Ride 'till
Vulcan 900
Boomer914 is offline
post #2 of 2 (permalink) Old 07-27-2019, 05:21 AM
https://www.vulcanforums.com/forums/...0-classic.html
There are also other threads in this forum about it.
When coming to lean angle, it's not the floorboards that are the culprit. They are hinged. The culprit is the floorboard brackets, and they are welded to the frame. They will stay there when you remove the boards. So, the maximum lean angle will not change by replacing the floorboards.
Let the good times roll
Frode is offline
