bike jack or stand - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 07-25-2019, 09:04 PM Thread Starter
bike jack or stand
I would like to use some of your esteemed wisdom on what I should buy and where the best price is for a stand or lift to do maintance on my 2010 Vulcan custom, I have not had a bike without a center stand in quite a while and need some information on what everyone else has that works. Any help would be appreciated, thanks ahead of time.
Big Blue's Daddy
Barry Dupler is offline
post #2 of 12 (permalink) Old 07-25-2019, 11:23 PM
Year/Make/Model: 2006 Vulcan 900 Classic, 1991 Honda 750 NightHawk
Displacement/CC's: 900, 750
Color: Red and Black
ATV jack
I used an ATV jack like this to do my rear tire.
These bike are low it was a little precarious but once position right bike was stable. Left bike on jack took wheel / tire to shop to have them install new tire. Changing tires at home is not worth the saving.
https://www.northerntool.com/shop/to...12a3ab5ecbc7e0
Shinko 230 Tour Master Tires Rear tire 180/70-15 Front tire 130/90-16
Biebs is offline
post #3 of 12 (permalink) Old 07-26-2019, 09:19 AM
Shadow01's Avatar
Shadow01 is online now
post #4 of 12 (permalink) Old 07-26-2019, 09:42 AM
Charles Brown's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan Custom
Color: Black and White
The jack shown in the service manual is a pancake-style jack. I purchased a similar kind off Amazon (there are all different types, these are generally made in China). Most hardware stores would probably sell these, they're the cheaper variety. The lifting part extends across the width of the motorcycle and there are rubber contact points that you can adjust so the underside doesn't get scratched.
Charlie
2016 Vulcan 900 Custom
Charles Brown is offline
post #5 of 12 (permalink) Old 07-26-2019, 12:13 PM
Hot Cruiser's Avatar
Got a motorcycle/ATV jack from O'Reilly's Auto on sale for $49. Only problem is that one has to be careful when positioning it under the 900 frame as the rubber padded lift points are barely wide enough. Otherwise it works well.
Jesus is Lord
Hot Cruiser is offline
post #6 of 12 (permalink) Old 07-27-2019, 08:47 AM
durox's Avatar
Year/Make/Model: 09/Vulcan900/Custom SE
@Barry Dupler
I've used all 3 kinds of jacks shown in the pictures with a VN900 Custom. They all work but it takes a few minutes with each one to find the proper spot... In most cases you won't need to lift both wheels off the ground, but if you want that option choose the model accordingly. The Scissor type ones cost less. The Craftsman one goes on sale every now and then for around $100.
MAKE SURE YOU DOUBLE CHECK the nuts and bolts of any new jack before use.
be safe, have fun.
durox is offline
post #7 of 12 (permalink) Old 07-27-2019, 09:18 AM
March411's Avatar
Year/Make/Model: 2019 Vulcan Classic
Displacement/CC's: 903
Color: Metallic Matte Graphite Gray/Metallic Matte Carbon Gray
This one has some pretty good reviews and has a small footprint and starts at only 4" tall. This is most likely the one I will grab.
Only a biker knows why a dog sticks his head out of a car window
March411 is offline
post #8 of 12 (permalink) Old 07-27-2019, 12:39 PM
BikeMadPete's Avatar
Year/Make/Model: 2012
Color: Sparkly black, whatever kawasaki call that.
Bike lift
I've got one similar to the Craftsman (Machine Mart bike lift) to which I've bolted two hardwood runners to run along my 900 classics' frame rails. It works ok but I do have to put a couple of 1/2 inch thick flat pieces of wood behind the front and rear whees and wheel it onto them to get the clearance for the jack to go under. If I'm going to have the bike up for a while I use a couple of ratchet straps to secure the bike to the stand.
BikeMadPete is offline
post #9 of 12 (permalink) Old 07-27-2019, 07:22 PM
Scottso's Avatar
20 bucks! Balance is perfect. You can see the back tire is off the ground. If you move it forward a bit the front tire will be off. BONUS if you get cold you can burn it for warmth!!
ID:	230152   Click image for larger version
ID:	230154   Click image for larger version
Scottso is online now
post #10 of 12 (permalink) Old 07-28-2019, 06:40 AM
...or just put a weight on the pillion.
Let the good times roll
Frode is offline
