Tapping USB ports into headlight? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By durox
post #1 of 8 (permalink) Old 07-22-2019, 12:53 PM Thread Starter
mike.caputo@mac.com's Avatar
Year/Make/Model: 2010 VN900 Custom SE
Displacement/CC's: 900
Color: Black
I have a USB port mounted to the handlebar for keeping my phone charged while using maps and music, etc. Right now, Iím using an SAE plug to tap into the battery. Works as it should, but itís annoying.
Is there a downside to just splicing it into the headlight wires? I want to make sure thereís no power drain when the bike is off.
I read the pinned thread about tapping into the switched relay under the seat - great tutorial but Iím wondering if itís more work than I need?
Would I blow the headlight fuse by charging my phone? I doubt it..
[email protected] is online now
post #2 of 8 (permalink) Old 07-22-2019, 08:39 PM
durox's Avatar
Year/Make/Model: 09/Vulcan900/Custom SE
if you are just using it for small devices and considering your phone charger is functioning properly, there is no danger in blowing fuses or causing damage to the wires...
think about it this way: both high and low beams can be ON without the fuse blowing.. but the fact that the back of the headlight is exposed to the elements, you should take extra precaution when insulating your work. i guess it depends where you're splicing, but that would be my main concern.
good luck, have fun, be safe ;}
*liquid electrical tape (or liquid rubber products) is my favorite way of insulating the wires on 18-wheelers... give it time to cure, do not use open flame..
[email protected] likes this.
durox is offline
post #3 of 8 (permalink) Old 07-23-2019, 07:59 AM Thread Starter
Color: Black
Ah, great advice! Thx!
post #4 of 8 (permalink) Old 08-02-2019, 10:47 AM Thread Starter
Color: Black
FWIW, I ended up running the wires from the handlebar-mounted USB ports to the rear running light, via under the tank and seat.
If a fuse or bulb were to blow out, Iíd rather it be the rear light than the headlight.
post #5 of 8 (permalink) Old 08-02-2019, 06:50 PM
Year/Make/Model: voyager 1700 ABS 2015
Color: charcoal green
Thumbs up usb plug
what I did on my I add a regular power plug in the trunk and use USB adapter on it ,and I add another in the front and use another USB adapter I did connected them to the battery so I can use it and keep charging my phone when the MC is off,, I did add a switch with a pilot light to been able to turn them off, the light to remind me to turn it off, or you can connect it to the wires on the power plug that came with the MC and it will go on and off with the ignition switch
irving is offline
post #6 of 8 (permalink) Old 08-02-2019, 10:19 PM
Year/Make/Model: 06 Vulcan Nomad, 05 and 04 Yamaha FZ1
Displacement/CC's: 1600 / 1000 x 2
Color: Green/Silver, Silver, Blue
I believe my 06 Nomad has an open harness under the seat just for accessory power.
Old Enough to Know Better
justacrossthehill is online now
post #7 of 8 (permalink) Old 08-03-2019, 04:33 AM
Ricksza's Avatar
Year/Make/Model: 2009 Kawasaki 900 Custom
Color: Burnt Orange
I mounted a power outlet beneath the fuel tank. It's wired directly to the battery through a fuse, so I can plug in my battery tender. I can use either a car charger cable or a USB adapter.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting
"WHAT A RIDE!"
Ricksza is offline
post #8 of 8 (permalink) Old 08-03-2019, 06:52 AM
whoaru99's Avatar
I did very similar for the same reasons. Exception being I used a handlebar-mounted power outlet.
whoaru99 is online now
