Fuel Pump Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 07-22-2019, 10:42 AM Thread Starter
SpringVulcan's Avatar
Fuel Pump Question
My bike, a 20009 Vulcan 900 Classic, has sat up for several years as I was out of the country. I disconnected the battery but forgot to drain the fuel the last time I ran it several months ago. (I was on a rotation so I was back in the US every 4-5 months).
It has a new battery and I drained the fuel and added fresh fuel with some FI cleaner. However, it won't start.
The Fuel Pump from what I can tell is not running at all. Removing the fuel line and no fuel comes out. The lights seem to come on and off correctly and I hear it prime when turning the bike on. But again, while it cranks it will not start and nothing comes out the fuel line.
Any thoughts?
Thanks!
2009 Vulcan 900 Classic (Zhaan)
OEM Windshield, Crashbars, Sissybar
OEM Slim Saddlebags
Crampbuster throttle control
Wagner BP1210/H4 headlight & 2357LL taillight
FIAMM Low tone horn
Homemade Lowers
SpringVulcan is offline
post #2 of 10 (permalink) Old 07-22-2019, 11:08 AM
RastaPasta's Avatar
Year/Make/Model: 2006 VC1600 Mean Streak
Displacement/CC's: 1552
Color: Black
If you can hear it priming, I would assume (perhaps incorrectly) that the fuel pump isn't the issue. I'd lean more towards the fuel lines going into/out of the pump being clogged or gunked up from the gas sitting for so long.
RastaPasta is offline
post #3 of 10 (permalink) Old 07-22-2019, 11:52 AM
Du-Rron's Avatar
Year/Make/Model: 2016 KAW VN900CGF
Displacement/CC's: 900
Color: Black/White
Well if the fuel pump is buzzing when you first turn the key and you "hear it prime" but no fuel coming out when you disconnect the hose (and leaving it disconnected at the same time) means: the pump has power, the pump is running, and you have a clogged fuel filter/junk in the bottom of the tank.
Drain the tank. Remove the fuel pump. De-crud the inside of the tank with some kerosene. Replace your fuel filters and try again.
https://www.highflowfuel.com/ag-1323...vn900-efi.html
Du-Rron is offline
post #4 of 10 (permalink) Old 07-22-2019, 02:59 PM Thread Starter
Checking things further: the noise we are hearing seem to be the throttle bodies opening and closing while doing their startup routine. Not the fuel pump. And we pulled the fuel line directly off the fuel pump and still nothing coming out.
OEM Slim Saddlebags
FIAMM Low tone horn
Homemade Lowers
post #5 of 10 (permalink) Old 07-22-2019, 03:07 PM Thread Starter
I think that was a mistake on my part. It isn't the fuel pump that I was hearing. It was the throttle bodies opening and closing. I think...
Putting a meter on the fuel pump seems to show no power.
OEM Slim Saddlebags
FIAMM Low tone horn
Homemade Lowers
post #6 of 10 (permalink) Old 07-22-2019, 03:13 PM
RastaPasta's Avatar
Color: Black
No power going to the pump then. First thing to check would be the fuse
post #7 of 10 (permalink) Old 07-22-2019, 03:51 PM Thread Starter
I that the 30A? It seems to be fine.
OEM Slim Saddlebags
FIAMM Low tone horn
Homemade Lowers
post #8 of 10 (permalink) Old 07-22-2019, 03:55 PM
Year/Make/Model: 2008 V900 Custom
Only because it has not been mentioned, be sure the kill switch is in the RUN position.
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
Last edited by westcoastkevin; 07-23-2019 at 07:49 AM. Reason: Correcting a misspelling.
westcoastkevin is online now
post #9 of 10 (permalink) Old 07-22-2019, 03:55 PM
RastaPasta's Avatar
Color: Black
I don't know your bike specifically, but my 06 Meanie 1600 has a diagram on the inside of the fuse box that lists what each fuse is for. If the fuses all check out though, try tracing the wiring going to the pump from the box to make sure a connector isn't loose or corroded, and make sure the ground isn't shorted out, corroded, or disconnected.
post #10 of 10 (permalink) Old 07-22-2019, 04:31 PM Thread Starter
Originally Posted by westcoastkevin View Post
Onlu because it has not been mentioned, be sure the kill switch is in the RUN position.
Good point. It sounds exactly as if the RUN switch is off. But I am sure it is on.
OEM Slim Saddlebags
FIAMM Low tone horn
Homemade Lowers
