Wompus Rack and saddle bags issue - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 1 (permalink) Old 07-20-2019, 03:22 PM Thread Starter
TommieH's Avatar
Year/Make/Model: 2014 Kawasaki Vulcan Custom
Displacement/CC's: 903
Color: Candy Lime Green
Question Wompus Rack and saddle bags issue
Hey guys. Is anyone using a Wompus Rack on there 900 classic/custom? And if so are you also using saddle bags? I installed my saddlebags using the fender bolt holes. I had to leave off my plastic bezel for this application. With the Wompus Rack it is installed using the plastic bezel/bolt holes. So my problem is that now my fender bolts holes are covered (by bezel and rack) and I can't reattach my bags. Not sure how the classic Vulcans are but the custom uses fairly small (in diameter) bolts. There's no way that I can install the weight of my bags and the rack w/king tour pak all on those tiny bezel bolts. Anyone had the issue of installing bags and rack/trunk before and figured out a custom way of fitting both without having to come up with a modification that will require way to much money and work?
Tommie Heady
TommieH is offline
