900 Vulcan Cables/Hoses - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
  • 1 Post By durox
  • 1 Post By rc4man
  • 1 Post By durox
post #1 of 6 (permalink) Old 07-17-2019, 01:37 PM Thread Starter
rc4man's Avatar
Year/Make/Model: 2009 Vulcan Custom SE
Displacement/CC's: 900
Color: Black/Copper
Have a 900 Custom that I'm wanting to add some set back risers and beach bars for my wife, to allow her easier reach and more leverage.
Are the Classic throttle, clutch cables and front brake hose longer than the Custom items or do they use the same ones?
If the same where should I look for extended items?
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline
post #2 of 6 (permalink) Old 07-17-2019, 02:12 PM
Year/Make/Model: 2008 V900 Custom
You do know the handlebars mount differently on the Classic and Custom, right?
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is online now
post #3 of 6 (permalink) Old 07-17-2019, 07:28 PM Thread Starter
rc4man's Avatar
Color: Black/Copper
The Custom uses a welded "T" bar with two legs that bolt through the top tree yoke, the Classic uses a standard bar clamped to two risers that bolt through the top tree yoke.
Both bolt through the top tree yoke.
Essentially no difference other than possible length of cables to reach levers and throttle tube.
rc4man is offline
post #4 of 6 (permalink) Old 07-22-2019, 09:48 PM
durox's Avatar
Year/Make/Model: 09/Vulcan900/Custom SE
@rc4man
the parts # are different between the two models regarding the cables.
see if the links for you:
custom: https://northvalleyhonda.dealerspike...479660e/cables
classic: https://northvalleyhonda.dealerspike...4796213/cables
rc4man likes this.
durox is offline
post #5 of 6 (permalink) Old 07-23-2019, 02:40 PM Thread Starter
rc4man's Avatar
Color: Black/Copper
Thanks durox, just wanted to be sure before I took a chance on ordering a set
durox likes this.
rc4man is offline
post #6 of 6 (permalink) Old 07-24-2019, 04:45 PM
durox's Avatar
@rc4man you're welcome.. a few years ago there were at least 2 options (brands) for some stainless steel brake lines and as I recall we had a few discussions on the forum regarding the necessary length.. I remember the black stainless ones were looking extra nice..
*As you probably found out, the brake lines are also different part numbers between the two VN900 models:
VULCAN 900 CUSTOM: HOSE-BRAKE,FR 43095-0250
VULCAN 900 CLASSIC: HOSE-BRAKE,FR 43095-0291
rc4man likes this.
durox is offline
