Speedometer stop working - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 07-03-2019, 03:49 PM Thread Starter
Mike.peltier's Avatar
Year/Make/Model: 2008 Kawasaki Vulcan 900c
Displacement/CC's: 889
Color: Black
I have a 2008 Vulcan 900 custom. I was riding home and all the sudden my speedometer stopped working. The lights and gas gauge seems to function just fine along with the clock and what not. I looked and didnít see any sensors or cables going to the front and back brake so where in the hell is the speedo cable. I also looked online at the bikes parts list and couldnít find a part number on bike bandit. Any help would be appreciated.
Mike.peltier is offline
post #2 of 15 (permalink) Old 07-03-2019, 04:14 PM
Archie's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Blue/Grey
The wire that connects the speedometer to the speed sensor is part if the wiring harness so you can't see it per se , the speed sensor is located at the back of the engine behind the coolant resevoir, try checking if the conector on the sensor came loose.
Archie is offline
post #3 of 15 (permalink) Old 07-03-2019, 04:17 PM Thread Starter
Color: Black
Iíll take a look now
post #4 of 15 (permalink) Old 07-03-2019, 04:42 PM Thread Starter
Color: Black
I donít see anything behind it.
post #5 of 15 (permalink) Old 07-03-2019, 04:55 PM Thread Starter
Color: Black
I believe I have found it. Itís on the right hand side crank case and it apparently leads under the seat where it connects to some module.
post #6 of 15 (permalink) Old 07-03-2019, 04:59 PM
Archie's Avatar
Color: Blue/Grey
You have to take the plastic tank off . so you can look at the back of the engine, if I can figure out how to sen you a picture I will send it to you , or you can try and get the service manual on line
Archie is offline
post #7 of 15 (permalink) Old 07-03-2019, 05:05 PM Thread Starter
Color: Black
Iíll start looking for a service manual. If you could figure out pictures that would be great.
post #8 of 15 (permalink) Old 07-03-2019, 05:18 PM
Archie's Avatar
Color: Blue/Grey
The sensor is mounted directly on the back of the crankcase , that module you have I think is to correct the speedometer's reading , that is usually 5% off , now there is where you should start try removing that module and take it from there,still trying to figure out the pictures LOL
Archie is offline
post #9 of 15 (permalink) Old 07-03-2019, 05:24 PM Thread Starter
Color: Black
post #10 of 15 (permalink) Old 07-03-2019, 05:40 PM
Archie's Avatar
Color: Blue/Grey
There you go !
Sorry I'm still trying to figure out how to post pictures
Archie is offline
