900 Custom: Moving Shift Peg? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By RastaPasta
post #1 of 8 (permalink) Old 06-27-2019, 09:17 PM Thread Starter
Year/Make/Model: 2009 Kawi Vulcan 900 Custom
Before I go loosening/removing things I don't need to, how do you reposition the shift peg upwards? I can barely get my new riding boot under the peg. Is it splined or do I have to loosen the nuts and play around with that connecting rod to the tranny? I only found talk of the Classic's heel/toe shifter and that wasn't that conclusive. Thank you.
Splat (yes, it's my nickname!)
Splat is offline
post #2 of 8 (permalink) Old 06-27-2019, 09:55 PM
RastaPasta's Avatar
Year/Make/Model: 2006 VC1600 Mean Streak
Displacement/CC's: 1552
Color: Black
Generally they're going to be splined. So just loosen it, pull the shift lever off, and find a spot you like then slide back on and tighten.
If it's been on there a while it probably won't want to slide off, so some WD-40 will help it slide off then take a wire brush to knock any accumulated corrosion off the shaft and the shift.
Splat likes this.
RastaPasta is offline
post #3 of 8 (permalink) Old 06-29-2019, 11:25 AM Thread Starter
Thanks, Rasta. It didn't look splined when I looked at it. Am I loosening the back connector at the tranny or at the front peg? Thanks.
Splat is offline
post #4 of 8 (permalink) Old 06-29-2019, 12:01 PM
Shadow01's Avatar
Hey Spalt, it looks to me like there is a dimple alignment dot on the rear linkage & on the linkage arm...so I wouldn't just pull off the rear linkage arm and re-insert it at a different location. That could mess up the overall geometry of the link arm relationship to the tranny shifter rod (extending out of the tranny).
The idea is to loosen the locknuts on the link rod (with rod with the heim ends) and rotate the link rod CCW or CW to get the shift peg to move up or down, as the case may be. Watch the threads on the heim ends & locknuts - one end is standard right-hand threads, and the other end is opposite LEFT HAND threads. Don't beat these locknuts up...observe the threads on the rod, and turn in the appropriate direction to loosen or tighten.
Once happy with the height of the shifter peg, tighten up the locknuts to torque spec.
E&OE. Use at your own risk.
Shadow01 is offline
post #5 of 8 (permalink) Old 06-29-2019, 02:13 PM
Year/Make/Model: 2008 V900 Custom
Displacement/CC's: 900
@Splat Shadow 1 has it right. Use the link rod.
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is offline
post #6 of 8 (permalink) Old 06-29-2019, 08:08 PM
jbiggers's Avatar
Year/Make/Model: 2013 Vulcan 900 Classic LT
Color: Sparkle Black and Titanium
Yep, use the link rod only.
jbiggers is offline
post #7 of 8 (permalink) Old 07-02-2019, 03:28 PM Thread Starter
Thank you very much, guys. I'll take a look tonight and see what I can break.
Splat is offline
post #8 of 8 (permalink) Old 07-03-2019, 11:28 AM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
Now that's an attitude I like!
SteveJB is offline
