I adjusted my valves today. - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By westcoastkevin
post #1 of 3 (permalink) Old 06-09-2019, 05:32 PM Thread Starter
Year/Make/Model: 2008 V900 Custom
Displacement/CC's: 900
Following my electrical saga that happened here:
https://www.vulcanforums.com/forums/...-no-start.html
I had to leave home for a few weeks a couple of days after I found and fixed the electrical problem. I got back home and was eager to button it up and let me late riding season start.
I did the valve adjustment while the tank was off.
The exhaust valves needed a thicker shim by 0.003" - 0.004"
Only one intake valve needed anything.
I replaced one hose clamp on a coolant line.
I cleaned the bottom oil screen and I put fresh oil and filter in it.
I put silicone dielectric grease on all of the electrical plugs. If I have to ever separate them again, I do not want them to fight me.
I gave the tank a good inspection. The inside was spotless. The outside has a few paint chips that I am dealing with. I relented and ordered a touch up kit.
However, I am glad I had the tank off and here is something that you should check too while yours is off.
The underside of the tank does not get complete paint coverage under the mounting flanges for the fuel pump assembly, and the fuel gauge assembly.
There was a bit of surface rust all the way around both of them right at the seam.
I dissolved that with ospho (phosphoric acid) and cleaned it with lacquer thinner.
Then I applied some fresh primer and paint with a q-tip all the way around the flange. It will never become a problem now.
I will add a few pictures later to explain it better. Anyway, If you have your tank off, you should inspect that area.
Time for dinner and then a ride.
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is offline
post #2 of 3 (permalink) Old 06-10-2019, 08:58 AM Thread Starter
I put new o-rings on the spark plug tubes while they were out.
The chart in the book is a bit overkill for doing the shims. I ended up just using the micrometer or caliper. It was faster and less error prone.
ID:	229310   Click image for larger version
ID:	229312   Click image for larger version
ID:	229314   Click image for larger version
ID:	229316   Click image for larger version
durox likes this.
PERFORMANCE:
Barons BAK intake
COMFORT:
Kuryakn ISO Grips
MISC:
Cobra Crash Bar
post #3 of 3 (permalink) Old 06-10-2019, 09:01 AM Thread Starter
This is what I was talking about regarding the paint coverage on the tank flanges.
I forgot to take a picture at the beginning.
In any case, you can see the rust getting dissolved.
I will never need to worry about it now.
ID:	229320   Click image for larger version
ID:	229322   Click image for larger version
ID:	229324   Click image for larger version
durox likes this.
PERFORMANCE:
Barons BAK intake
COMFORT:
Kuryakn ISO Grips
MISC:
Cobra Crash Bar
