Starts but will not stay running - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 05-16-2019, 11:54 AM Thread Starter
Year/Make/Model: 2007 Classic, 2009 Classic
Displacement/CC's: 900/1600
Color: Red /Blue &Black
I have just acquired a 2007 900 that has been sitting for 10 years. Replaced the fuel pump, cleaned tank, new plugs new battery. It has 43 miles on it. I can get it to start but not run more than 10 - 15 second then slowly quits. Have cleaned injectors. I want to be able to check and make sure the ECM is working correctly but I need help.
Steve
[email protected] is offline
post #2 of 18 (permalink) Old 05-16-2019, 01:36 PM
Hot Cruiser's Avatar
According to the VN900 shop manual there is no way of testing the ECM itself directly, but only by testing its functions with the components which it regulates. From your description the problem could be related to the fuel or/and air supply.
Other members may have more useful suggestions.
Jesus is Lord
Hot Cruiser is offline
post #3 of 18 (permalink) Old 05-16-2019, 01:41 PM Thread Starter
Sent from my SM-G935V using Tapatalk
post #4 of 18 (permalink) Old 05-16-2019, 03:03 PM
SpinDog's Avatar
Maybe check the air filter for mouse debris.
--2010 900 Classic--
--Argus Battery Bug--
--Cobra rack, passenger backrest, passenger floorboards, tachometer--
--Saddlemen Cruisn Teardrop Saddlebags w/ Quick-Disconnect Mounting Kit--
--Kawasaki windshield & lowers--
Other bike: R1200RTW
SpinDog is offline
post #5 of 18 (permalink) Old 05-16-2019, 08:11 PM
If you can, post a video.
sfair is offline
post #6 of 18 (permalink) Old 05-16-2019, 09:54 PM Thread Starter
Upload fails when I try to add attachment
post #7 of 18 (permalink) Old 05-17-2019, 05:16 AM Thread Starter
Tried yesterday evening and this morning, would not start at all. It doesn't seem to be getting gas, new fuel pump seems to be working but injectors do not seem to be opening. Got the manual and will start going through the test for all the related sensors. Posted video, maybe this will helphttps://cloud.tapatalk.com/s/5cde894e...517_061057.mp4
post #8 of 18 (permalink) Old 05-17-2019, 09:45 AM
Year/Make/Model: 2008 V900 Custom
Are there any codes?
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is offline
post #9 of 18 (permalink) Old 05-17-2019, 09:50 AM
Do not go wildly poking here and there, but use a logical troubleshooting technique.
Employing guesswork could easily introduce another fault and then the real tail chasing begins.
1. Attempt a start and then immediately remove the plugs to check for being fuel soaked, or?
2. Why/how did you clean the injectors?
To bad you could not have taken the video when it would start and stall as that can give clues to the possible problem.
sfair is offline
post #10 of 18 (permalink) Old 05-17-2019, 11:16 AM Thread Starter
That is what is next, to go through it logically. Start with the pump, then again on the injectors the the sensors that may he locking it out. Thanks for the help and I will keep you informed on my progress.
Steve
Running and brake lights. Gibson90kb General Vulcan Talk 10 06-19-2014 01:06 PM
2008 Vulcan 500 rough running triscaler New Member Introductions 1 05-22-2014 10:43 AM
Bike won't stay running... remtx79 Vulcan 1500 2 05-19-2014 01:22 PM
Rear Turn Signals / Running Lights? Kankujoe Vulcan 500 20 08-17-2012 06:37 AM
starter engaging while engine running kngmaximus Vulcan 800 2 05-29-2011 08:58 PM
