2007 vn900 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 04-25-2019, 06:58 AM Thread Starter
Marty_vn_900's Avatar
Year/Make/Model: 2007 Kawasaki vn 900
Displacement/CC's: 903
Color: Red
2007 vn900
Hi all
Anyone taken rear wheel off , im thinking of doing this
To check bearings and give her a good lubing up , have done this on other bikes with drive chains but never drive belt just worried about drive belt adjustment, Iíve had the bike over 2 years now and I donít know how long drive belt has been on it looks ok , bike has done 16K . Read online about changing drive belt and you have to take part of the swing arm off donít want to have to do that . Thanks
Ride safe
Marty_vn_900 is offline
post #2 of 5 (permalink) Old 04-25-2019, 08:56 PM
gosupes's Avatar
Year/Make/Model: 2008 Vulcan Custom
Displacement/CC's: 900
Color: Black
If had mine off a few times. I hear there is a tool that the dealers use for belt tension, I just went from memory and some common sense. I think its detailed as the belt will deflect a certain distance with x amount of force. As for alignment, when I had the rear wheel off the ground, i spun the tire by hand while watching the belt. Once it was close and not riding the edges of the pulley, i went for a 20 mile ride. When I got home, I noticed the belt had moved a little. A small adjustment, and it's been good since. It's really not a big deal, easier than my old shaft drive bike. As for belt replacement, if there isn't signs of obvious damage, I would keep running it.
Rules to live by:
Never trust a fart after a night of fast food.
Never take a laxative and a sleeping aid on the same night.
When riding, wear gear you don't mind having a wreck in.
Don't ride above your skill level.
gosupes is offline
post #3 of 5 (permalink) Old 04-25-2019, 09:46 PM
Tynker's Avatar
Year/Make/Model: 2009 Kawasaki Classic LT
Color: Green & Silver
Unless the belt has damage from rocks etc. it should last as long as the bike. There is nothing to lube on the rear wheel, all the bearings are sealed, but maybe a little grease on the axle to keep it from rusting , and make it easier to remove.
Tynker is offline
post #4 of 5 (permalink) Old 04-26-2019, 09:11 AM Thread Starter
Color: Red
Thanks for replyís guys
Much appreciated itís doesnít sound to much different than chain adjustment . Iíve seen that adjustment tool and like you said gosupes i donít think itís necessary. Sealed bearings is a bonus as is the drive belt just need to check it regularly, greasing the axle sounds like a job next time Iím off work a few days
Thanks again guys feel a lot more confident now .
Ride safe
post #5 of 5 (permalink) Old 04-26-2019, 04:00 PM
Hot Cruiser's Avatar
As others have posted the drive belt should last as long as the motorcycle unless it has been damaged. Adjusting belt tension - I got a tool from a Harley dealer source which puts the required deflection testing pressure on the belt as seen at the adjusting slit on the belt guard. Cost about $6, makes testing easier. Amazingly the belt on mine has not needed adjusting except when replacing the rear tire. Overall a 1000% improvement over rear wheel drive chain systems.
Jesus is Lord
Hot Cruiser is offline
