Can you change the fork oil while forks on on the bike? - Kawasaki Vulcan Forum : Vulcan Forums
 4Likes
  • 1 Post By btom
  • 3 Post By Sabre-t
post #1 of 6 (permalink) Old 04-07-2019, 01:31 PM Thread Starter
Zzman's Avatar
Year/Make/Model: 2006 900 LT
Displacement/CC's: 900
Color: Blue and silver
Can this be done or are forks removed?
Zzman is offline
post #2 of 6 (permalink) Old 04-07-2019, 02:22 PM
D0ncH's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan Classic
Color: Black & Chrome
I believe you can but you have to remove the front tire to get to the drain plug/hole. Someone with more knowledge then I will probably correct chime in
Sent from my SM-G930W8 using Tapatalk
2006 Vulcan 900 Classic
D0ncH is offline
post #3 of 6 (permalink) Old 04-07-2019, 03:42 PM
gosupes's Avatar
Year/Make/Model: 2008 Vulcan Custom
Color: Black
I haven't done forks on the Vulcan, but my experience on other bikes is that it might be possible, its probably easier just to remove the tire and slide the fork out from the trees.
Rules to live by:
Never trust a fart after a night of fast food.
Never take a laxative and a sleeping aid on the same night.
When riding, wear gear you don't mind having a wreck in.
Don't ride above your skill level.
gosupes is offline
post #4 of 6 (permalink) Old 04-07-2019, 03:49 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
keep the forks on the bike, just remove the caps and clip and plug then springs then suction out the oil using a copper tube with plastic clear hose attached or you can insert the copper tube and let gravity do its thing to drain what's at the bottom of the fork cavity
durox likes this.
btom is offline
post #5 of 6 (permalink) Old 04-07-2019, 04:03 PM
Hot Cruiser's Avatar
According to the Kawi shop manual the forks have to be removed so that they can be tipped upside down with the caps removed to drain the oil completely. Seems to be from the Dark Ages - my ancient 1978 Yamaha 650 had drain screws at the bottoms of the forks to make oil change easier. Obviously other members have developed work-arounds for the 900.
Jesus is Lord
Hot Cruiser is offline
post #6 of 6 (permalink) Old 04-07-2019, 09:46 PM
Sabre-t's Avatar
Color: Red/Black
You can change the fork oil with the forks on, but you shouldn't. The old oil builds up acids and needs to be removed completely. You can't do that with the forks on the bike. Well, not unless there is a drain at the very bottom that is ok to use for that purpose.
Take the forks off, turn them upside down to drain, and pump them to get all of the old oil out. I always put a little clean oil in them, pump them upright then turn them over and drain with more pumping. This clears out almost all of the old oil.
durox, glhadiator and Denny606 like this.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
Fork Oil Change pmassey31545 Vulcan 1500 4 11-10-2015 06:40 PM
I'm a female rider. I watched this video and did my first oil change! germanchocolate New Member Introductions 0 08-26-2012 04:55 PM
Fork oil change gibi Vulcan 1700 8 07-28-2012 06:01 AM
Maintenance questions mainly about Changing fork oil/ brake fluid MichelleS Vulcan 500 1 06-23-2011 01:24 PM
fork oil change lwolford75 General Vulcan Talk 0 07-04-2008 12:01 AM
