Grease fittings - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 07-01-2009, 10:10 AM Thread Starter
silenthill's Avatar
Grease fittings
Can anyone post pics on location of all grease fittings for the vn900classic.
Thanks and regards, Silenthill
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #2 of 10 (permalink) Old 07-01-2009, 11:02 AM
Jeep Pirate's Avatar
I only know of three so you may want to ask someone who has the maintenance book. The three I know about are on the very lowest point of the bike. It is an aluminum bracket that mounts to the frame and the rear shock. I do not understand why some "in-guh-neer" would put fittings on the bottom of the bike since if you bottom out, they get damaged. I have two that are deformed and one of those seems to have damaged the threads in the aluminum housing it screws into.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #3 of 10 (permalink) Old 07-01-2009, 12:00 PM Thread Starter
silenthill's Avatar
Thanks Jeep, I went and had a look, wow......your right, and, as I've been driving a dual sport for the last 3 plus years, its just donning on me that I don't have an engine guard. I think I'll have a think on this, there must be a way to protect them. I scraped my floorboards last night (for the first time). I can only assume bottoming out will be the next "scuff" that I will do.
Cobra luggage rack.
post #4 of 10 (permalink) Old 07-01-2009, 03:33 PM
I have hit the floorboards a couple times going around sharp corners. Especially if the pavement is not level or there is a big dip between two roads. That doesn't bother me to bad.
I think I may have damaged mine putting her on a trailer one day. The angle from the ramp to the trailer deck was to acute and she hung. Sort of like a rice-burner going over a speed bump.
I actually just stopped by the local bike shop and picked up two new fittings at lunch. Since these are only pivot points and not high revolution shafts, I am not to concerned. As long as a little grease is in there, it should be fine. There isn't a lot of heat or pressure pushing the grease out. The worst thing is that your ass end might start squeaking when you go over bumps.
'07 VN900 Classic
post #5 of 10 (permalink) Old 07-01-2009, 07:52 PM
Picture from under bike.
leepotter is offline
post #6 of 10 (permalink) Old 07-02-2009, 06:54 AM Thread Starter
silenthill's Avatar
Thanks for taking the time to post that pic!
Most appreciated,
Regards-Silent
Cobra luggage rack.
post #7 of 10 (permalink) Old 07-02-2009, 03:05 PM
ChevelleSSLS6's Avatar
it wasn't me! lol!
ChevelleSSLS6 is offline
post #8 of 10 (permalink) Old 07-02-2009, 04:27 PM
teamsunbelt's Avatar
Just for your info, hit a speed bump the wrong way and the middle one wil "FALL OUT".
'08 VULCAN 900 Custom
GenMar Risers
Mustang 2 Up Seat / Mustang Tank Cover
Cobra Back Rest w/ Plate
Cobra Luggage Rack
Willie & Max Revolution Bags
Memphis Shades Windshield
Kuryakyn Iso Grips w/ Throttle Boss
Smoked Signals
Dually Rear Pegs
teamsunbelt is offline
post #9 of 10 (permalink) Old 07-04-2009, 09:13 AM
what's the right way to hit a speedbump?
post #10 of 10 (permalink) Old 07-04-2009, 10:40 AM
Jace Bror's Avatar
Well I can tell ya you are going too slow if you don't get the front wheel off the ground when you go over them.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
Grease fittings? Coreyashaw93 Oil and Lubrication 2 04-03-2017 07:41 AM
Rocker Arm Grease Zerks/Nipples/Fittings Missing!! Wild Bill Vulcan 900 11 02-26-2016 06:32 AM
Zerk Fittings How often should i pump grease in em??? BlackedOutVulcan Vulcan 900 8 07-22-2011 05:32 PM
banjo fittings for a '96 EN 500 LTD rodmen Vulcan 500 3 01-05-2011 07:18 PM
2010 Grease Fittings CGCWO Vulcan 900 5 05-08-2010 10:19 AM
