seafoam - Kawasaki Vulcan Forum : Vulcan Forums
 8Likes
post #1 of 19 (permalink) Old 03-31-2019, 02:46 PM Thread Starter
Quintr0's Avatar
Year/Make/Model: 2014 vulcan 900 custom
Color: green
seafoam
could someone tell me what sea-foam is, and how to use it? is it different from startron enzyme additive?
lightcs1776 likes this.
Quintr0 is offline
post #2 of 19 (permalink) Old 03-31-2019, 02:49 PM
RastaPasta's Avatar
Year/Make/Model: 2006 VC1600 Mean Streak
Displacement/CC's: 1552
Color: Black
I can't tell you what it's made of, or how it does what it does, but I can tell you it's marketed as a fuel additive/stabilizer, it seems to also work great to clear gunk from old/bad fuel, and it not meant to be drunk.
Just pour some in the gas tank and slosh it around. The bottle has a measurement based on volume of fuel youre mixing it in with, but I just pour a full can in when I put the bike away for winter to keep the gas from getting all gunky.
RastaPasta is offline
post #3 of 19 (permalink) Old 03-31-2019, 02:49 PM
Year/Make/Model: 2008 Kawasaki Vulcan Nomad 1600D
Color: Blue / Silver
Seafoam is a cleaner, as far as I am aware. I put it in the tank of my '82 Yamaha XJ750 every now and then. Some folks also put it in their oil to keep things cleaner. I can't say how it compares to other chemicals, since I only know it by the brand name.
Sent from my DROID Turbo using Tapatalk
2005 Vulcan Nomad 1600D (purchased Aug, 2018).
lightcs1776 is offline
post #4 of 19 (permalink) Old 03-31-2019, 03:25 PM
VN750Guy**'s Avatar
Displacement/CC's: 750
Color: Red/black
IF and I say IF you put in in your oil, you MUST change out the oil in about 50 miles. This stuff will clean like a son-of-a-gun in both the fuel system (which is good) and in the oil (which is good ONLY as a real temporary thing). I've used it in my oil, too, but I was going to change the oil and filter out anyway. I basically put it in and ran around for some 20 to 30 miles and then dumped it.
So if you're machine has sat for a long, long time, or you have reason to believe there's gunk in there for whatever reason its fine to put SeaFoam in the crankcase AS A MEANS TO CLEAN IT OUT. But you don't want it in for long term.
For fuel system cleaning, just follow the directions on the can. Its money well spent.
lightcs1776 and AirborneSilva like this.
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #5 of 19 (permalink) Old 03-31-2019, 07:32 PM
arobsum's Avatar
Year/Make/Model: 2005 Vulcan VN2000A
Displacement/CC's: 2000
Color: metallic blue
the seafoam tutorial on youtube states to add 1 ounce per quart of oil and to drive vehicle between 100 to 300 miles....being we are on motorcycles i would go with the above opinion and go no further than 50 miles just to be safe. it works when used with some common sense...lol good luck.
Life. Nobody gets out alive.
arobsum is offline
post #6 of 19 (permalink) Old 03-31-2019, 11:44 PM
VN750Guy**'s Avatar
Color: Red/black
But getting back to the original question about SeaFoam and Startron enzyme additive: I've not heard of the Startron stuff before. I don't know, therefore, what the similarities or differences are. My experiences with SeaFoam are good though.
Chris Cochran
Luggage rack
Home made lowers
post #7 of 19 (permalink) Old 04-01-2019, 12:13 AM
Sabre-t's Avatar
Color: Red/Black
According to the MSDS, Star Tron Enzyme Fuel Treatment is >95% heavy naptha with >0.5% other solvents. To me, that is just snake oil. A heavy naptha will clean carbs and injectors and probably absorb some moisture better than gasoline, but not that much better. And what is an enzyme going to do in a combustion engine? That's as ridiculous as claims that "oxygenated" bottled water has some magical properties.
Again from the MSDS, Seaform is a proprietary solvent mixture plus isopropyl alcohol. The alcohol is what makes it a good fuel stabilizer as it helps to prevent water from falling out of the gas, which is a problem any time with E10 gas, but especially when it sits for long periods with changing temps.
Both products will clean carbs and fuel injectors some, but, if you want to clean carbon and varnish from carbs and injectors with a gas additive, injector cleaning additives with PEA (polyetheramines) do a much better job. Techron, Red Line, and Royal Purple (my choice) are among the best in this category.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #8 of 19 (permalink) Old 04-01-2019, 02:20 AM
It makes your wallet lighter.
durox likes this.
VulcanDrifter is offline
post #9 of 19 (permalink) Old 04-01-2019, 07:06 AM
Color: Black / grey
Sorry but int the last few days I've seen a bunch of posts about what Seafoam and other additives contain.
On here and other places.
The majority of us dont really care what's in it - sorry.
BUT if it cleans and makes you vehicles - bike or car or truck - ruin run better, cleaner, longer - and its not a billion bucks, it's money well spent!
Seafoam is one of those.
I've used it as winter storage stabilizer, and fuel tank addition for keeping the fuel system clean on the bike.
Cant complain about how it works, or the cost!
vulcandoc is offline
post #10 of 19 (permalink) Old 04-01-2019, 09:20 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
I use seafoam as a gas stabilizer and put about a third cup of seafoam into my gas tank in November during bike storage and fill up the tank with gas to expel all the air so the inside of the tank doesn't rust up,
btom is offline
Damn screws & Seafoam in carbs now... budwizest Vulcan 500 2 06-16-2016 03:52 PM
Seafoam in Carbs and damn screws budwizest Engine Work 3 06-06-2016 05:34 PM
Interesting seafoam video Romans5.8 General Vulcan Talk 13 05-12-2015 04:45 PM
Seafoam through Vacuum line? Fuel line? Juancho Vulcan 500 5 10-23-2013 10:23 PM
How to use Seafoam on Motorcycle? shobuddy Engine Work 23 03-16-2010 10:41 PM
