Issues Downshifting - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 03-13-2019, 06:15 PM Thread Starter
Mancalledhorse's Avatar
So, I noticed recently went trying to downshift, my gear shifter felt like it wasn't connected to anything and wasn't "catching" to downshift. I would be stuck on 5th/4th gear etc.
I can upshift easily, but once in a while, I can't downshift. So far it is intermittent (not continuous). The best way to describe it is the shifter feels disconnected, empty. I have to stop and keep tapping down until I feel the "clunk".
I don't hear any unusual noises from the case. My clutch doesn't slip or drag. I'm in that 0.2-0.3mm clutch cable play.
I have a 2012 classic with 2012. Last oil change was 1,000 miles ago.
Does anyone know what this is?
Mancalledhorse is offline
post #2 of 2 (permalink) Old 03-13-2019, 06:27 PM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
There are two splined shafts that the shifting mechanism is connected to. I would first check to make sure neither of these bolts that clamps the splines has loosened, causing your shaft to slip in the splines.
Bandit101 is online now
PSA: Report brake/clutch switch issues to NHTSA Romans5.8 Vulcan 1700 14 07-24-2016 12:24 PM
'01 1500 Classic FI possible throttle issues... boredfool Vulcan 1500 3 09-16-2015 05:54 PM
Have Key Issues Been Fixed? If So, When? vulcan0007 Vulcan 900 7 02-18-2014 12:56 AM
Oil light illuminating more often when downshifting StrokedCutlass Vulcan 1500 3 08-04-2013 02:15 AM
A question for those that are having stalling issues. twowheeladdict Vulcan 1700 14 09-01-2010 11:21 AM
