Led lights - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
  • 1 Post By btom
  • 2 Post By RickD
post #1 of 10 (permalink) Old 03-07-2019, 01:41 AM Thread Starter
Ohiocowboy78's Avatar
Led lights
Anyone have suggestions on the best led replacements? I'd like to redo the whole bike. Thanks.
Ohiocowboy78 is offline
post #2 of 10 (permalink) Old 03-07-2019, 07:42 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
www.customdynamics
RickD likes this.
btom is offline
post #3 of 10 (permalink) Old 03-07-2019, 04:26 PM
RickD's Avatar
Year/Make/Model: 2012 VN900B
There are a bunch of threads on this topic. The search tool is your friend. Custom Dynamics makes some great products for the turn signals. There are quite a few good H4 replacement bulbs on Amazon (many swear by the OPT7 brand...I'm partial to Auxbeam), and 1157 brake bulbs as well. SuperbrightLEDs.com has nice bulbs for the console if you're going all the way.
https://www.vulcanforums.com/forums/...mic-ringz.html
bearslayer and D0ncH like this.
Chrome saves lives.
RickD is offline
post #4 of 10 (permalink) Old 03-07-2019, 04:32 PM Thread Starter
Thank you. I've done searches on Amazon and just didn't know which direction to go.
post #5 of 10 (permalink) Old 03-07-2019, 05:16 PM
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
I concur about CustomDynamics. I've always had great service and gotten good products. They've got a slew of options for ya.
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #6 of 10 (permalink) Old 03-07-2019, 08:46 PM
Shadow01's Avatar
Also, remember to search for an issue around replacing the front blinkers with LEDs. There is a feedback through the green indicator lamp on the dash panel that causes both of the front blinkers to flash at the same time if you replace the front bulbs with LEDs. Sorry, I probably didn't explain that correctly, but do a search and you'll find the issue and the "fix". I left my front 1157 bulbs "as-is" for that reason. All others are LED.
Shadow01 is offline
post #7 of 10 (permalink) Old 03-07-2019, 09:07 PM
jbiggers's Avatar
Year/Make/Model: 2013 Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Sparkle Black and Titanium
I used JDM Astar LEDs for the 1156 (rear) and 1157 (front) as replacements, and a red LED 1157 for the brake light. Also had to do the single green blinker indicator mod to correct both sides blinking at the same time. Also had to get an LED compatible flasher to replace the original flasher. Then got a Cyclops 7k lumen H4 LED lamp to replace the headlight bulb.
jbiggers is offline
post #8 of 10 (permalink) Old 03-11-2019, 07:37 PM
Misfire's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Custom
Color: Candy Surf Blue
There's a post on here, a sticky if I'm not mistaken, that fixes the LED feedback problem. I did it in about 45 minutes. Search for it. It's a little soldering in your console... Tight spaces, but it wasn't that bad.
Sometimes you find diamonds in the ashes of your previous endeavors and losses.
Misfire is offline
post #9 of 10 (permalink) Old 03-12-2019, 06:53 AM
jbiggers's Avatar
Took me about 1.5 hours to do the console mod, but I took my time with it, went slow and careful.
jbiggers is offline
post #10 of 10 (permalink) Old 03-12-2019, 08:31 AM
RickD's Avatar
Here is the thread on the diode mod: https://www.vulcanforums.com/forums/...-solution.html
I can testify that I have done this mod myself following these very well written instructions (including heat shrink tubing as per post #10) and it works perfectly.
Chrome saves lives.
RickD is offline
LED lights (Head Lamp / Tail Lamp) hckeynut15 Vulcan 2000 3 06-24-2017 09:11 AM
LED Tail lights on Meanie uncl3f3st3r Vulcan 1600 0 02-25-2015 06:39 PM
Kisan SignalMinder installed now thinking about LED lights Rogereh Vulcan 900 13 05-04-2014 06:12 AM
LED Driving Lights 3degree Vulcan 1500 9 04-15-2011 10:50 AM
New LED brake lights ..WOW ostbob Vulcan 1500 8 03-30-2011 04:28 PM
