Idle - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 22 (permalink) Old 03-01-2019, 08:47 AM Thread Starter
I have a 2007 Vulcan 900 classic LT the bike runs great only thing that kinda worries me is that when i start it it doesn’t have a high idle. It’ll start with an idle of about 800 rpm and as it warms up it’ll get to 1000 rpm. What could be wrong that it doesn’t have a high idle at start up? Is it something to worry about?
torresrene is offline
post #2 of 22 (permalink) Old 03-01-2019, 09:04 AM
Color: Black / grey
If its a carb bike then you need to use the choke!
If fuel injection then the computer is controlling it.
And since you didnt say that it had an idling problem, it must be starting fine??
900 likes this.
vulcandoc is offline
post #3 of 22 (permalink) Old 03-01-2019, 10:25 AM Thread Starter
It’s fuel injected. It’s starts right up every time. And once at running temp it’s idles perfect at 1000 rpm. It’s just when I first start it it’ll idle at about 800 rpm instead of a high idle since it’s cold.
post #4 of 22 (permalink) Old 03-01-2019, 10:37 AM
Color: Black / grey
OK. Then its fine.
I had a car that didn't have a high idle either. and it would start and idle fine even at extreme low temps.
As I stated the computer controls the idle speed, and your saving your engine by NOT having it run at a high idle at start up!
Nothing wrong with it.
post #5 of 22 (permalink) Old 03-01-2019, 10:42 AM
By design, it should high idle on start-up. If it does not, then something is not right.
Check high idle sticky at the top of the 900 section.
sfair is offline
post #6 of 22 (permalink) Old 03-01-2019, 10:58 AM Thread Starter
OK. Then its fine.
the only thing that concerns me is that the idle at start up is only about 800rpm then as it warms up it progresses to about 1000rpm.
post #7 of 22 (permalink) Old 03-01-2019, 11:03 AM
Archie's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Blue/Grey
Check if the throtle valve actuator is not sticking due to gunk accumulation or not working
Archie is offline
post #8 of 22 (permalink) Old 03-01-2019, 11:19 AM Thread Starter
how would I check that?
post #9 of 22 (permalink) Old 03-01-2019, 11:59 AM
Did you read the sticky????
sfair is offline
post #10 of 22 (permalink) Old 03-01-2019, 12:13 PM Thread Starter
would carburetor cleaner work?
Requires advance idle knob for cold startups Elitemuppet Vulcan 1500 0 09-22-2018 01:24 PM
Hanging idle and popping from carburetor starlightfury Vulcan 500 16 06-27-2016 01:25 PM
1999 vulcan 1500 jetting woes and stumble johnnybass Vulcan 1500 30 07-02-2013 10:49 AM
Exhaust backfire style loud pop and Idle adjustment. ta-kid Vulcan 1700 9 05-31-2013 10:45 PM
Annoying Fast Idle Tinkering 1945 Vulcan 900 16 09-15-2010 04:58 PM
