2007 Vulcan 900 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 02-09-2019, 12:44 AM Thread Starter
2007 Vulcan 900
I recently bought a 2007 Vulcan 900 LT with 8400 miles. I have done some maintenance on it like oil change,spark plugs,air filter, and blend the brakes. I noticed a bit of carbon build up on my exhaust. And the bike did sound a bit low on rpm and messed with the idle screw by ear. And later bought a digital tach to set the idle to spec I used setting 2p1r on it. But don’t know if it’s correct. I set it to about 1000 rpm but it sounds a bit on the high side. I want to know what the spark/pulse input on these Vulcans.
torresrene is offline
post #2 of 11 (permalink) Old 02-09-2019, 09:12 AM
Year/Make/Model: 2006 Vulcan 900 Classic, 1991 Honda 750 NightHawk
Displacement/CC's: 900, 750
Color: Red and Black
2p1r
2p1r digital tach setting?? Wrapped wire around spark plug wire?? These big twins like to lop at idle about 800rpm
2007 with8400 miles sound like a sitter!! You did the oil check coolant level and ride it!! Make sure the rad fan comes on after a long ride when it is hot outside - will not work this time of year or maybe if idled for a long time.
This bike needs some miles!!!
How old are the tires?? Original 2007?? Need new!!
One more note when cold like AZ is now these bikes make lots of strange noises no choke fuel injected use a air valve system to choke for cold weather. I see you are a Minnie so tan almost a cheesehead!!!
Put on the thermo coveralls and go ride!!!
Biebs is offline
post #3 of 11 (permalink) Old 02-09-2019, 12:21 PM
Hot Cruiser's Avatar
Kawi spec for idle on the 900 is 1000 RPM. Do not set lower - insufficient oil pressure at lower RPM to lubricate the camshafts and valve gear.
Jesus is Lord
Hot Cruiser is offline
post #4 of 11 (permalink) Old 02-09-2019, 12:53 PM Thread Starter
Bike has good rubber metzeler me880. Just trying to set the idle to spec. And it is the type of tach you wrap around the spark plug wire. I had set it to about 1000 but sounds a bit high. So I don’t know if before the bike was just at a really low idle or the tach isn’t accurate. Or maybe even on the wrk g setting.
post #5 of 11 (permalink) Old 02-09-2019, 04:44 PM
gosupes's Avatar
Year/Make/Model: 2008 Vulcan Custom
Color: Black
2P/1R should be 2 coil pulses per 1 engine revolution. Called a wasted spark ignition, plug fires on compression and exhaust stroke. Pretty common.
Also as stated, 1000 rpm is spec.
Rules to live by:
Never trust a fart after a night of fast food.
Never take a laxative and a sleeping aid on the same night.
When riding, wear gear you don't mind having a wreck in.
Don't ride above your skill level.
gosupes is offline
post #6 of 11 (permalink) Old 02-09-2019, 06:17 PM Thread Starter
So the 2p1r is the correct setting? And do you know how accurate these wire tachs are?
post #7 of 11 (permalink) Old 02-09-2019, 09:20 PM
900 is single fire...1 spark event per 720 degrees of crankshaft rotation.
sfair is offline
post #8 of 11 (permalink) Old 02-10-2019, 08:17 AM
gosupes's Avatar
Color: Black
I must have been looking at specs for a different size Vulcan. Now that I think about it, when I wired up my tach, there was a single fire adapter. My bad.
Rules to live by:
gosupes is offline
post #9 of 11 (permalink) Old 02-11-2019, 08:17 PM
Bike Of The Fall Winner 2017
GFISH's Avatar
Displacement/CC's: 903
Color: Silver
When I had mine put on a dyno. The mechanic said she's happy when sits at 1000 rpm's.
"As long as I have the voices in my head, I'll never ride alone."
2006 Vulcan 900 classic
Mustang Day Tripper seat
Cobra Light Bar
Cobra Air Scoop
Cobra short sissy bar
Cobra Lowers
Baron's front and rear pulley
Baron's Big and Nasty pipes
Leatherlyke hard bags
Blue Superbrites LED accent lights
Chrome Woo Loo Air Horn
Avon Grips
GFISH is offline
post #10 of 11 (permalink) Old 02-12-2019, 05:03 AM
END OF YEAR BIKE 2018 Winner
Year/Make/Model: 2006 Classic LT (Buffy)
Color: Blue/Silver/Chrome
What @GFISH said...I take mine to a very experienced Tech/Mech and he said the same thing, "She's very happy at 1,000."
...On a Steel Horse I ride...
glhadiator is offline
Aftermarket seat for 2007 900 custom marvinsanremo Wanted to buy or trade Items 0 08-25-2014 11:48 AM
2007 Vulcan 900 Custom located in South Florida 4500.00 ALF Bikes For Sale 7 03-23-2014 05:16 PM
2007 Vulcan 900 Classic $4500.00 obo jcor2213 Bikes For Sale 0 02-05-2014 04:41 PM
2007 Kawasaki Vulcan 900 Custom bluevulcan9 Bikes For Sale 3 10-13-2013 10:40 AM
