Lighting issues - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 2 Post By dmonger
post #1 of 9 (permalink) Old 01-06-2019, 08:39 AM Thread Starter
dmonger's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan 900 Classic
Displacement/CC's: 900
Color: Blue
Lighting issues
So this morning when I hopped on the bike to head into work I noticed my speedo wasn't illuminated. The fuel, temp high beam lights all worked however. So I figured the bulb finally burnt out. The bike is 13yrs old and things are going to start breaking bulbs are gonna burn out and the like. I was planning on figuring out how to replace it and be done with it, however I noticed when I pulled into the garage at work my tail/brake light wasn't working either. Now I am beginning to wonder if there isn't a short due to water getting into the wiring behind the license plate light plastic cover. Is the speedo and brake light wired together like that or is it just dumb luck I had two bulbs burn out at the same time?
si vis pacem para bellum
dmonger is offline
post #2 of 9 (permalink) Old 01-06-2019, 12:08 PM Thread Starter
dmonger's Avatar
Color: Blue
So update:
Decided to go check again and while the key is turned to run I have no speedo illumination or brake, however when turned to Aux or whatever it is after run, my tail light turns on but brake light doesn't flash like normally it would. I'm assuming it's because it's not on the run position. So now I am even more confused. Does anyone have any idea why it would turn on in aux but not run?
dmonger is offline
post #3 of 9 (permalink) Old 01-06-2019, 01:12 PM
Year/Make/Model: 2008 Kawasaki Vulcan Nomad 1600D
Displacement/CC's: 1552
Color: Blue / Silver
I had a similar issue with an old Yamaha, where the lights went out. For me, it was a loose ground connection at the battery. The bike didn't have an aux setting, so it may well not fit your senerio.
Sent from my DROID Turbo using Tapatalk
2005 Vulcan Nomad 1600D (purchased Aug, 2018).
lightcs1776 is offline
post #4 of 9 (permalink) Old 01-06-2019, 04:04 PM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
Check the tail light fuse. Asian built cars often have dash lights and tail lights on the same fuse because you can't easily see when the tail light is out. Maybe here too. If that's a VN900, you don't have an aux on the ignition. It's a park setting so can leave the tail light on at night if you have to park it road side. That is a separate circuit with its own power lead.
SteveJB is offline
post #5 of 9 (permalink) Old 01-06-2019, 08:56 PM Thread Starter
dmonger's Avatar
Color: Blue
It was the 10a fuse, checked it while I was at work. Thanks for the suggestion. Also, I was only assuming it was aux. I wasn't sure what the position was actually called thank ya.
Demoliton Man and lightcs1776 like this.
dmonger is offline
post #6 of 9 (permalink) Old 01-07-2019, 03:42 AM
Bandit's Avatar
Year/Make/Model: 2014 Vulcan 900 Custom - 2018 Yamaha XT250
Displacement/CC's: 900/250
Color: Candy Lime Green - Sandy Beige
Glad to hear it was an easy fix.Hopefully the fuse does not blow again.Usually something causes it.
2014 Kawasaki Vulcan 900 Custom
2018 Yamaha XT250
Bandit is offline
post #7 of 9 (permalink) Old 01-07-2019, 04:56 AM
SteveJB's Avatar
Glad to hear that got it. Here's to hoping it was just a bad fuse.
SteveJB is offline
post #8 of 9 (permalink) Old 01-07-2019, 05:02 AM Thread Starter
dmonger's Avatar
Color: Blue
That what was my thought, but at the same time the bike is 13yrs old with 63k miles so it's seen better days and I am hoping it just wear and tear.
dmonger is offline
post #9 of 9 (permalink) Old 01-07-2019, 08:59 PM
jbiggers's Avatar
Year/Make/Model: 2013 Vulcan 900 Classic LT
Color: Sparkle Black and Titanium
SteveJB, I did not know that aspect of Japanese autos. And it seems to apply to Japanese motorcycles as well. Excellent tip.
jbiggers is offline
shorting wires? funny lighting issues Project84 Vulcan 900 15 10-07-2013 08:30 AM
Lighting issues macd2898 Vulcan 1500 2 09-02-2013 11:20 AM
LED lighting discussion jerryneyk Vulcan 500 9 10-01-2009 05:15 PM
LED Accent Lighting PolishBulldog Vulcan 900 33 05-21-2009 02:00 PM
Electrical/lighting questions PerfectStranger Vulcan 500 1 10-19-2008 10:57 PM
