Hard to shift? - Kawasaki Vulcan Forum : Vulcan Forums
 5Likes
post #1 of 20 (permalink) Old 05-25-2017, 06:21 PM Thread Starter
Misfire's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Candy Surf Blue
Hard to shift?
Maybe I'm missing something, and I was hoping some of the more experienced and knowledgeable folks in here might be able to point me in the right direction.
Bike: 2010 Vulcan 900 Custom
Problem: when she's cold, she's a dream to ride (except when the high-idle goes all stupid), but after about 10-20 minutes of riding, downshifting seems like is fighting me, and neutral is almost impossible. I've flattened the toe of my boot, and used all the muscle I could muster in my leg to try that one little half click up from first. Nothing. Won't budge. Not the first time, either. Kill the engine, and it works fine... I've already bent the shaft once due to the downshift issue, but neutral should pull, not push. I'm lost, but I'd rather it not kill me...
Any ideas?
Sometimes you find diamonds in the ashes of your previous endeavors and losses.
Misfire is offline
post #2 of 20 (permalink) Old 05-26-2017, 08:36 AM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
Are you doing this downshifting while still moving or at a complete stop?
Jeff, Twin Cities, MN
MN-Rider is offline
post #3 of 20 (permalink) Old 05-26-2017, 04:51 PM Thread Starter
Misfire's Avatar
Mostly rolling. Once or twice at a stop.
Misfire is offline
post #4 of 20 (permalink) Old 05-27-2017, 10:16 PM
Shadow01's Avatar
Sounds like a clutch adjustment is in order...don't fight the shifter - that'll bend & break stuff.
glhadiator likes this.
Shadow01 is offline
post #5 of 20 (permalink) Old 05-29-2017, 04:31 PM Thread Starter
Misfire's Avatar
Well, I've adjusted the clutch a few times since replacing the cable due to a little stretching, but my sweetspot doesn't start until about a quarter inch off the grip... It's in specs for the model as well... So I'm not sure what to adjust outside of that...
Misfire is offline
post #6 of 20 (permalink) Old 05-29-2017, 08:16 PM
Year/Make/Model: 2008 V900 Custom
You might, just might, try a different oil.
It might be dragging more in the plates of the clutch when it gets hot, even with the lever pulled in. You might have to adjust it a bit more if you have a lot of miles on the clutch.
Does it happen in all of the downshifts or just some?
5-4
4-3
3-2
2-1
2-N
1-N
westcoastkevin is online now
post #7 of 20 (permalink) Old 05-30-2017, 12:16 AM
Shadow01's Avatar
Hey Misfire, I am going by "memory" here - but - it seems to me that if you are getting "into the sweet spot" for the clutch engagement at 1/4 inch off the grip - that is too soon...I would say my clutch isn't even thinking about engaging that early - more like 1/2 inch to 3/4 inch before I get any drag on the clutch...not doing this scientifically - but its more than 1/4 inch off the grip, for sure.
I'm not sure why you have had to re-adjust your clutch lever so often - you say its because you are getting "a little stretching" on a new clutch cable...wow...I think I have adjusted my clutch lever free play once in 12,000km, and that was at around 1,000km from new. Nothing since.
Having not seen/ridden your bike, I'd be thinking you have too much free play in the cable. It is suppose to be 2-3mm gap when you take-up the slack in the cable...you know how to do this measurement, right? Do you have a service manual?
At the end of the day, if you are using the correct oil (I'm assuming you have motorcycle oil in the bike), have triple-checked your clutch lever free play according to the service manual, and you still cannot down-shift or find neutral, then your trouble could be in the shift mechanism, shift fork, return spring, or shift pawl. You'll need to test those parts using the service manual.
durox and glhadiator like this.
Shadow01 is offline
post #8 of 20 (permalink) Old 05-30-2017, 09:27 PM
colemantle's Avatar
What oil do you run? Is it old?
colemantle is offline
post #9 of 20 (permalink) Old 06-02-2017, 09:18 PM Thread Starter
Misfire's Avatar
The oil makes sense. It's due for a change, add it stands. Haven't been riding much add of the past couple weeks... Nothing but rain and work. 3-2 and 2-1 on occasion, but the worst one I'd say I'd 1-N...
I think I used standard oil on the last oil change... Soon as the weather clears up, I'll get to a flat surface and try bike oil again this round and see if it clears up.
Lastly, I've got it adjusted correctly by the book. And by quarter inch, I meant free play, not cable drag to the sweet spot.
Thanks a ton folks...
Misfire is offline
post #10 of 20 (permalink) Old 06-03-2017, 08:09 AM
Sonny's Avatar
Year/Make/Model: '09 V900 Classic
Displacement/CC's: dead stock
Color: Plasma blue
If your clutch lever freeplay is correct, you should be getting into the friction zone earlier and achieving full disengagement earlier in the pull.
durox and krcruse like this.
Sonny is offline
Hard to Shift to 1st and Disengages at 1st tedkawi Vulcan 900 15 08-22-2013 01:25 AM
hard shift since it got cold ramcharger Vulcan 2000 15 10-17-2012 11:19 PM
Hard to down shift into 1st Wifesmechanic Vulcan 800 5 08-13-2010 11:07 AM
Hard shift from first to second... vulcanologist Vulcan 1500 2 06-04-2010 08:37 PM
Hard to shift kw4tx Vulcan 1500 2 09-23-2009 05:30 PM
