Strange vibration & noise - Kawasaki Vulcan Forum : Vulcan Forums
 8Likes
post #1 of 15 (permalink) Old 04-07-2017, 05:05 AM Thread Starter
Year/Make/Model: VN900 CLASSIC 2007
Displacement/CC's: 900
Color: RED
Hello,
I noticed something that maybe an issue or not, I am new to VN900 although not to Vulcans in general.
Around 4k rpm and only when the engine is in gear a vibration develops that produces a slight ringing (?) noise coming from under the seat or the engine I believe, I cannot pinpoint it due to the fact that it only happens when I am riding, if give it gas stationary in neutral it does not occur and it stops when I pull the clutch to change gear when cruising.
I will check the belt tension but I would appreciate any ideas on where else to look at.
Thanks!
darkkon is offline
post #2 of 15 (permalink) Old 04-07-2017, 12:29 PM
i had a rattling sound and after sending it in with a warranty check up it was something todo with the headlight, the garage put some tape or something in there and fixed it right up
2015 Vulcan900 Custom
supaginge is offline
post #3 of 15 (permalink) Old 04-07-2017, 03:50 PM
Millennium Vulcan's Avatar
Year/Make/Model: 2008 Kawasaki Vulcan LT
Color: Blue & Silver
Mine does the same thing. I still don't know if it normal or not.
Some people see a light at the end of the tunnel. Others see a TRAIN!
Millennium Vulcan is offline
post #4 of 15 (permalink) Old 04-07-2017, 03:50 PM
rc4man's Avatar
Year/Make/Model: 2009 Vulcan Custom SE
Color: Black/Copper
If you're rolling and pull in the clutch if it were the belt it would still make noise.
darkkon and Millennium Vulcan like this.
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline
post #5 of 15 (permalink) Old 04-08-2017, 03:05 AM Thread Starter
Color: RED
I am afraid it is not that simple as the noise appears only at a certain high RPM range.
darkkon is offline
post #6 of 15 (permalink) Old 04-08-2017, 03:09 AM Thread Starter
Color: RED
I guess it's nothing serious as these decade old bikes would have suffered engine failure if it were
I do most of the maintenance myself, including valve adjustment, so I have to find it myself or with the help of this community as I do not trust any dealer or shop to lay hands on this beauty!
Millennium Vulcan likes this.
darkkon is offline
post #7 of 15 (permalink) Old 04-09-2017, 07:55 AM Thread Starter
Color: RED
As I was checking stuff I noticed the rear shock upper nut was loose to the point of falling off the bolt 😨
I torqued it to 44 lb/ft and hope all is well!
Previous owner had lowering kit installed and maybe the mechanic forgot to tighen the bolt?
Who knows, I will keep an eye on it.
darkkon is offline
post #8 of 15 (permalink) Old 05-03-2017, 10:04 AM Thread Starter
Color: RED
I bought a belt tension tool and checked deflection, it is about 8 mm across the belt at 3 different locations. Should I tighten it a bit to the 4mm recommended or not bother with it?
darkkon is offline
post #9 of 15 (permalink) Old 05-03-2017, 01:47 PM
no the manual seems to be a little too tight, maybe check the axel alignment
post #10 of 15 (permalink) Old 05-03-2017, 03:52 PM Thread Starter
Color: RED
Alignment looks good, both sides point at the same notch.
darkkon is offline
Strange Noise XSXLR8R Vulcan 2000 48 08-19-2014 04:50 AM
strange noise special K Vulcan 1700 24 01-12-2012 06:06 PM
strange noise in exhaust dthom74 Vulcan 800 2 07-26-2011 08:44 PM
Strange noise Cleanevo Vulcan 800 8 07-12-2011 09:54 PM
Strange Noise from front lower portion of Motor dkurth General Vulcan Talk 0 05-20-2010 09:15 AM
