oil light - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 05-30-2009, 08:21 PM Thread Starter
boffo's Avatar
Question oil light
I have a vulcan 900lt after washing it the oil light came on. Before washing everything was normal. Oil level is okay this bike has only 900 miles on it. Is it possible the water afected the light engine sounds normal?
boffo is offline
post #2 of 6 (permalink) Old 05-31-2009, 07:05 AM
cruznut6's Avatar
The most common reason the oil light comes "on" is the idle speed is set too low. Does the light go "out" when you increase the rpms?
Bob
NJ Bikers For Christ
Colossians 2:10- And in Him you are made Complete.
2006 V2K LT
cruznut6 is offline
post #3 of 6 (permalink) Old 05-31-2009, 07:37 AM Thread Starter
boffo's Avatar
Started it up this morning and no oil light which makes me think that the pressure washing was the problem some how. It is running normal maybe moisture affected the light.
boffo is offline
post #4 of 6 (permalink) Old 06-01-2009, 05:12 AM
1945's Avatar
Pressure washing is not good for engines, cars or bikes. Once water gets in the wrong places there will be a new corrosion path.
1945 is offline
post #5 of 6 (permalink) Old 06-01-2009, 07:53 AM
It's possible the water pressure turned the idle speed adjuster? Baitis is right, pressure washing a bike is a bad idea. The spray from a normal garden hose is as much water pressure as you should ever put on it.
rpgpgmr is offline
post #6 of 6 (permalink) Old 06-01-2009, 01:13 PM
Don't EVER pressure wash your bike. That pushes water in past seals in your engine, hubs, chain, etc. NOT GOOD.
cbrfreak is offline
tail light, brake light, running light not working Rider_otStorm General Vulcan Talk 6 02-02-2018 08:35 PM
cut wire for neutral light and oil light! rebeltitanfan63 Vulcan 500 2 04-06-2013 11:25 AM
No brake light, No tail light????? UscgMac Vulcan 2000 7 09-04-2010 10:45 PM
Oil Light and Temp Light On Olympic335 Oil and Lubrication 2 07-17-2010 05:00 AM
