VN900 won't start, good battery - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 19 (permalink) Old 02-24-2017, 12:36 PM Thread Starter
Year/Make/Model: 2007 Kawasaki VN900 custom
Displacement/CC's: 900
Color: red
VN900, only about 4000 miles, obviously pampered life, always garaged. Suddenly won't start. Battery was weak so I replaced it. Still just cranks and cranks. Removed filter and sprayed starting fluid in intake, no change.
Short time before complete no start it was hard starting and backfired a bit before straightening out and running decently.
Any thoughts?
jonzo454 is offline
post #2 of 19 (permalink) Old 02-24-2017, 01:10 PM
Remove and post a picture of the plugs.
Do not use starting fluid.
FerricOxide63 likes this.
sfair is offline
post #3 of 19 (permalink) Old 02-24-2017, 01:38 PM Thread Starter
Color: red
It is below freezing currently. I will post the picture as soon as it warms up a little.
What damage will starting fluid do? I have used it to troubleshoot fuel injected cars before.
jonzo454 is offline
post #4 of 19 (permalink) Old 02-24-2017, 01:40 PM
What did you learn by using it?
sfair is offline
post #5 of 19 (permalink) Old 02-24-2017, 01:43 PM Thread Starter
Color: red
The vehicle had a bad fuel pump.
jonzo454 is offline
post #6 of 19 (permalink) Old 02-24-2017, 02:22 PM
No, I mean on your motorcycle.
sfair is offline
post #7 of 19 (permalink) Old 02-24-2017, 03:46 PM Thread Starter
Color: red
Oh. No change. Still no attempt to fire.
jonzo454 is offline
post #8 of 19 (permalink) Old 02-24-2017, 05:12 PM
That is why I do not recommend ether. It does not advance your knowledge base and there is always a risk of backfire and subsequent inferno. If the engine should start, one usually gets a brutal knock because of the uncontrolled burn of ether.
Have you checked for spark? Be careful that if you do that, you get no ether exhausted onto the plug and an ignition.
While the plugs are out, post a picture of them.
sfair is offline
post #9 of 19 (permalink) Old 02-25-2017, 01:20 PM Thread Starter
Color: red
I pulled the rear plug. It's really gas-soaked. I am ordering 2 new plugs.
Name:	2007 Kawa 900 rear plug3.jpg
jonzo454 is offline
post #10 of 19 (permalink) Old 02-25-2017, 05:03 PM Thread Starter
Color: red
I changed the plugs for fresh replacements. It now starts and runs. I ordered a K&N air filter too.
jonzo454 is offline
dead battery? bike won't start kdbarry Vulcan 900 26 05-13-2015 12:57 PM
charged battery now bike won't start Jingle New Member Introductions 24 07-29-2014 02:21 PM
Won't start, battery charged, starter SPINS !!! JoeCubicle Vulcan 900 24 04-01-2013 09:29 PM
Bike Won't Start, if it does, won't idle xantonin Vulcan 500 17 10-06-2012 07:49 PM
Bike Won't START, clicks won't turn over. jimartina Vulcan 800 44 04-27-2011 04:17 PM
