Questions building a Lightbar - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 04-18-2012, 06:36 PM Thread Starter
Rescue Wagon's Avatar
I want to build my own light bar to fit my style and I was curious what power lights are typically used. Also, for those who have built their own whats the best way to build the bar?
2008 Vulcan 900 Custom
Cobra Dragster Pipes
Cobra Fi2000
Classic Rear Fender
Harley Tour Pack
Running on the Darkside
Rescue Wagon is offline
post #2 of 3 (permalink) Old 04-19-2012, 10:04 AM
Jeep Pirate's Avatar
Most aftermarket lightbars use 20w or 35w halogen bulbs. The main trick is that the stator on the bike is only rated for an additional 70w of load. So if you have any other add-ons that use power, you have to add up all the watts to see what you can stand. I unfortunately added 140w a couple years back and toasted my stator over about a year. Just because the lights work does not mean that you are not overheating your stator and in the long run will probably have to replace it if you add to much load.
As for building one, I can't really help much there. I did the Wally World lightbar thing at one time. But that is just a matter of clamping a couple lights to the little chrome bar that runs under the headlamp on the Classic. In your case, you may be able to make a couple brackets that attach where the turn signals are located.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #3 of 3 (permalink) Old 04-19-2012, 10:12 AM Thread Starter
Thanks for the info. I've been talking with a couple of companies about re-winding a stator for a higher output. I'm going to be using my 900 for touring the country and eventually the world so power seems to keep coming to the top as an issue I'm going to have to address.
Cobra Fi2000
Classic Rear Fender
Harley Tour Pack
Questions questions questions Heathen129 Vulcan 2000 3 05-07-2016 11:41 AM
building a custom vulcan 800 motocrossnut00 General Vulcan Talk 4 11-03-2010 08:16 PM
Building some pipes this weekend. vulcanbobber Vulcan 800 4 10-16-2010 07:57 PM
help on 82 550 ltd building bobber RONFOX New Member Introductions 3 10-24-2009 09:06 PM
