Tach/Electrical people, got a question for ya... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 04-13-2012, 02:27 AM Thread Starter
Color: Orange SE
Hey,
So I've got an old Auto Meter tach sitting in my closet. I was wondering, if I set it to 4 cylinder mode, with no single fire adapter, what would my readings be like? I'm not wanting to mount it, I'm just wanting to get my idle set because I'm paranoid it's not right, it feels too high, but I also don't want it to be too low (just debaffled and it's throwing me off)
I remember on my old Cougar if I flipped it down to 4 cylinder mode I could convince people I had a souped up stock car engine under the hood turning a 5.0L V8 8k+ RPMs LOL.
So my question is, how to wire it up just to test, and, what my readings would be like. If it's cut in half, or even in a quarter, that's no big deal as it's an accurate tack. I'll just set my idle for 250rpms in that case (aka 1000rpms)
Thanks!
John
Romans5.8 is offline
post #2 of 16 (permalink) Old 04-13-2012, 10:14 AM
Seawolf_il's Avatar
Tach help
It would show 1/4 the revolutions, unless you build your own single-fire tach adapter, in which case it would show 1/2 revs.
If you have been around a soldering iron before, you can build this for like $2 worth of parts from RadioShack/Fry's/etc in minutes.
Good luck
Seawolf_il is offline
post #3 of 16 (permalink) Old 04-13-2012, 10:18 AM Thread Starter
Color: Orange SE
Good luck
Even with 1/4 revolutions it wouldn't be bad... this is just for diagnostics... not gonna mount it. Where do I hook everything up? I can figure out the hot +12v and ground pretty easy, but there is one lead that comes out that goes to the ignition, where does that attach on the 900?
post #4 of 16 (permalink) Old 04-13-2012, 12:24 PM
Your Autometer should have 4 wires:
1. Tach power.
2. Coil negative ( rpm)
3. Tach ground.
4. Instrument light.
Connect 1 to coil positive.
Connect 2 to coil negative.
Connect 3 to battery ground.
Do not connect 4.
sfair is offline
post #5 of 16 (permalink) Old 04-13-2012, 12:31 PM Thread Starter
Color: Orange SE
1. Tach power.
3. Tach ground.
Do not connect 4.
Forgive my I-Don't-Know-That-I'm-Doingness, but which ones are coil positive and which ones are coil negative (on the bike?) I haven't pulled the cover off yet though, it might be extremely obvious (like a red and black wire). It's storming right now though so she's hiding under her cover
post #6 of 16 (permalink) Old 04-13-2012, 12:47 PM
I should have said that in my first post:
Coil positive is red wire.
Coil negative is black or black/green wire depending on which coil you select
sfair is offline
post #7 of 16 (permalink) Old 04-13-2012, 01:47 PM
Seawolf_il's Avatar
You want to attach the tach lead to one of the coil output negative wires, not the ignition...you aren't mounting it right? Ignition lead would only be to light-up the display at night.
post #8 of 16 (permalink) Old 04-13-2012, 03:56 PM Thread Starter
Color: Orange SE
When I had it mounted on my old Cougar, it was years ago but if I remember right one wire went to a positive lead in the fuse box, one went to the dash light lead from the stereo, one to ground and one to the distributor I THINK. It's been a while, and back then I had the instructions
If I could figure out a way to make it read correctly and subsequently waterproof it I might just mount it in the future. Any way that's possible? It only does 4/6/8 cylinder modes so, as I understand it, my best scenario would be 1/2 the rpms with a single fire adapter right? Don't wanna mount it in that case.
Oh, and it's a Sunpro, not an autometer. Although I thought I had an autometer somewhere too... I dunno.
post #9 of 16 (permalink) Old 04-13-2012, 04:20 PM
The wire that originally connected to your fuse box can go to coil positive.
Ignition lead is not for lighting.
sfair is offline
post #10 of 16 (permalink) Old 04-13-2012, 04:21 PM Thread Starter
Color: Orange SE
Yeah the lighting one is definitely all on it's own. It's a shorter wire and runs to the backlight bulb. It's dimmable and everything. Won't need that though (unless I do mount it down the road). Just wanna get my idle set.
Anyone wanna take a guess at how to maybe makeshift a way to make this tach read 100% correct? A few bucks on resistors and such would be nicer than $100 on a tach!
Dyno tuning question for people that have actually run a dyno Fried Chicken Blowout Engine Work 0 08-09-2015 11:55 AM
Got the shop tach, now what tach settings? BrewinProf Wrench Heads 1 09-16-2014 09:25 AM
Tach wring problem....or just a bad tach? xringer Vulcan 900 8 08-10-2013 07:58 PM
Engine Stopped blowing oil mist. Ya got me!!! Windburn Bill Vulcan 1600 24 12-21-2012 11:49 AM
Question/help for you super people Gobbledot Vulcan 1600 7 07-30-2011 09:58 PM
