Front running lights.?? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 04-12-2012, 06:22 PM Thread Starter
Mr-BZ's Avatar
Ok I've searched the forum but can't seem to find this.. Does anyone know how to disable the front running lights?(amber ones) I only want the turn signals to work when needed. Thanks.
2010 vn 900 custom se
Sent from my Motorcycle iPhone app
Mr-BZ is offline
post #2 of 10 (permalink) Old 04-12-2012, 06:26 PM
Ol'Yella's Avatar
don't know if its legal but if you follow the wire harness back use a volt meter or wire schematic to find the wire that feeds the running lights you could unplug the connector and remove(not cut) the pin from one side of the plug seal it up so it doesn't corrode plugs things back in and there you go. Doesn't seem like a good idea to me but it's your ride do it up.
08' 900 Classic solar indy yellow
Ol'Yella is offline
post #3 of 10 (permalink) Old 04-12-2012, 06:43 PM Thread Starter
Mr-BZ's Avatar
Ok I'm gonna give it a try. Thanks
Mr-BZ is offline
post #4 of 10 (permalink) Old 04-13-2012, 09:05 AM
BZ, there's 3 wires to the front turns, the blue one is the wire for the running lights. If you cut/disconnect the blue wire from turns and seal up you should just have front turns with no running light capabilities. I see you live in PA too, and I've read PA motorcycle code up and down about the lights and it's not required you have running lights for the front turns only your headlight. As some riders are keen to having more visibility, they advise you to keep your running lights, but I have the same bike as you and I chose to go for the "stealth" look with loud pipes lol.
2010 VN900 Custom
I have this addiction.....it can't send me to jail, but it sure can make me go broke....
Azellas is offline
post #5 of 10 (permalink) Old 04-13-2012, 09:58 AM
Color: Orange SE
Can I ask, why you want to?
Romans5.8 is offline
post #6 of 10 (permalink) Old 04-13-2012, 02:46 PM Thread Starter
Mr-BZ's Avatar
Yeah, I read the law also and didn't see that I needed them. But thanks for the info. And yeah that's what I'm doing, going more blacked out. Got the black seat, waiting on my pipes and just ordered smoke turn signal covers, and Then I'm gonna paint the turn signals gloss black.
Mr-BZ is offline
post #7 of 10 (permalink) Old 04-13-2012, 08:01 PM
Try to replace the bulb with a single filament bulb. Not sure right now which one, but i think it will work.
sent from downstairs bathroom while pooping thanks to Verizon.
scorpio_vette is offline
post #8 of 10 (permalink) Old 04-13-2012, 08:28 PM Thread Starter
Mr-BZ's Avatar
Have u done this to your lights? If so are u using the same bulbs?
Mr-BZ is offline
post #9 of 10 (permalink) Old 04-13-2012, 08:40 PM
Ol'Yella's Avatar
I do suppose you could file down the solder nub on the low filament side on the bulb. put a little peice of E tape over it and be done without wiring or (unwiring) anything. But I don't think there is a single filament bulb that is offset to only use one side of the dual socket.
Ol'Yella is offline
post #10 of 10 (permalink) Old 04-14-2012, 02:48 PM Thread Starter
Mr-BZ's Avatar
Worked great, thanks.!! And I got my smoke lenses today, they look awesome, so I might not even paint the signals now.
Mr-BZ is offline
Converting front turn signals to running LED white lights? JonF Motorcycle Safety And Riding Gear Discussions 23 02-05-2019 02:22 AM
No dash lights no running lights wont start FTW2017 Vulcan 1500 0 09-26-2017 10:13 PM
Does the 2009 Custom have front running lights? XJS Motors Vulcan 900 17 06-29-2016 08:09 PM
Tail lights and running lights keep blowing fuses golfer49 Vulcan 500 2 08-27-2015 10:23 PM
running lights used as brake lights ? mc-rider Vulcan 1600 1 05-17-2010 05:26 AM
