cenrtain i have water in fuel 2006 vn900 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 04-11-2012, 06:45 PM Thread Starter
siphoned of a quart and let it settle have a small puddle of water at the bottom treated the fuel waited a day took it for a ride didnt clear up! think i have a LOT of water . want to remove tanks any one know HOW THAT RED CLIP COMES OFF THE FUEL LINE ?
ltclimb is offline
post #2 of 5 (permalink) Old 04-11-2012, 07:08 PM
Just get a small flathead screw driver and pry it towards you. Just be careful with it that you don't break it
dry_kill is offline
post #3 of 5 (permalink) Old 04-11-2012, 07:49 PM
Just a suggestion. I don't know how much water you have in your tank, but I would suggest buying a bottle of Heat fuel additive. You could add 1/2 bottle to the tank. It will absorb the water in your Kaws fuel system. I would add some regardless if you drain the tank or not, to make sure you get all the water out of your fuel system. Don't be confused with the alcohol in gasohol and this additive they are different. One is ethanol, the other is isopropyl alcohol.
http://www.startribune.com/business/36707014.html
mdsimon80 is offline
post #4 of 5 (permalink) Old 04-11-2012, 10:58 PM
As mentioned the red clip slides away from the connectors but doesn't come off.
Sojourner is offline
post #5 of 5 (permalink) Old 04-12-2012, 02:35 PM
Color: Orange SE
+1 on Heet added to get the water out. Seafoam will also stabilize the fuel of water but not as well as heet. Drain it, but use the heet afterwards to make sure your fuel system and residual water in your fuel tank is dry.
Romans5.8 is offline
2006 VN900 Fuel Pump jeezfreek Wanted to buy or trade Items 0 03-10-2013 05:09 PM
Fuel processor, have or have not. dogg Vulcan 2000 9 09-24-2012 12:02 PM
Refilling water to water reservoir barchaim Vulcan 500 2 06-19-2012 02:47 PM
How many people have had water pump bearing failures louichie Vulcan 1500 0 10-08-2009 05:54 PM
