Headlight bulb warning - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 04-06-2012, 08:32 PM Thread Starter
Amerimutt's Avatar
Wagner H4 100/80watt light warning
This was advise I took and wish I didn't. Good intentions or not-Bad advise!!
Maybe you got one in your bike and are as happy as fish that stole the bait.
Anyway, this thing exploded and made one hell of a mess. Luckily, I don't know when it happened, but when I discovered it, I couldn't figure what the hell happened with this strange illuminating. (pictured is not the light on...it's the mess)
Regardless, this created a mess that's not easy to clean up. I found the light/lens, is a sealed chamber..after wasting my time disassembling.
Never the less, I washed out the light bowl and put the stocker back in, rode around awhile with no problems.
BTW the H4 100/80 was in the bike maybe two days before it blew.
ID:	10059   Click image for larger version
It's all fun and games till someone gets the joke!
Amerimutt is offline
post #2 of 4 (permalink) Old 04-06-2012, 09:23 PM
Yup Halogen bulbs will do that if you even touch them with you finger, any oil or dirt at all on the bulb will cause a hot spot and shatter the bulb.
When I put one in I wash my hands first, hold only the metal part of the bulb, clean the glass bulb with alcohol and a q tip and then when dry, seconds, insert in slot.
Many people use the Wagner bulb with success I am on my second bulb with zero issues. Just make sure it's clean when it goes in.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #3 of 4 (permalink) Old 04-06-2012, 09:59 PM Thread Starter
Amerimutt's Avatar
Happy fish, I used extreme and clean caution when I put it in.
Thanx for your recommendations.
post #4 of 4 (permalink) Old 04-06-2012, 10:16 PM
Thats odd,have had the wagner bulb in my 06 for over a year.Replaced the 10a fuse a month or so after putting it in(original fuse) then recently( after a year) had to replace a blown fuse again.Other than that have had no issues. If thats all I have is a blown fuse once a year to keep that bright light I will deal with it!
xxxxxxRTL Rider is offline
Replacement Headlight Bulb b1unt3d Vulcan 500 12 03-15-2012 07:53 AM
Headlight Bulb Replacement vulcan800 Vulcan 800 4 07-12-2010 08:55 PM
headlight not working no power at bulb or high low switch 00flatvulcan Vulcan 800 7 03-03-2010 07:39 PM
Headlight bulb boffo Vulcan 900 6 08-17-2009 06:25 PM
Headlight bulb Gabriel Vulcan 2000 14 05-29-2009 02:32 PM
