VN900C frame - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 1 (permalink) Old 04-05-2012, 08:20 PM Thread Starter
VN900C frame
Has anyone mounted an air horn on the frame above the shifter? If so, what did you use for a mounting bracket? I tried to look up p-clamps in the 108 - 110 mm range. Not much luck. Maybe I just measured it wrong. I came up with approx. 4 1/4" around. Anyone have a suggestion? thanks
Like my Mom says, you're a long time dead! Live now! Anyone have some wood that I can knock on?
Tahdi is offline
VN900C new owner questions smcdk9 Vulcan 900 8 08-10-2010 06:11 AM
2009 VN900C A/F ratio readings Kawieman Vulcan 900 2 05-23-2010 06:50 PM
07' vn900c valve shim specs wirenutt1956 Engine Work 3 09-16-2009 02:38 AM
VN900C Randomly Unable To Change Gears benjydog Vulcan 900 13 05-26-2009 10:02 PM
VN900C photos! Puck90a Vulcan 900 6 08-04-2008 04:06 PM
